What Does The Pro P...
[Closed] What Does The Pro Pedal on my dhx 5.0 do?
[#4171924]
i know its ment to minimise pedal bob but how does it work? and should it be turned off for going downhill? also im 11 stone and ive got a 600x2.8 spring do i need a softer one?
Posted : 17/07/2012 10:33 pm
Turn it off for going downhill
Posted : 17/07/2012 10:36 pm
It's a low speed compression damping circuit. Not only reduces pedal bob but increases pumpability so nice on jumpy stuff.
Posted : 17/07/2012 10:37 pm
And yes you need a softer one. Go to www.tftuned.com and use the spring calculator...
Posted : 17/07/2012 10:39 pm
ran mine on a middle of the road setting normally, cranked it up for tough climbing.
As above gave some stability at low speed
wow im ment to have a 350 spring not 600! goona be a massive diffrence
Posted : 17/07/2012 10:45 pm
I keep PP cranked up, but my 222 is prone to bobbing.
Posted : 17/07/2012 10:48 pm
do i need to turn it off for going downhill? should the shock not work properly with it on? from what the other guy says "It's a low speed compression damping circuit" does this not mean its not effecting the main shock funtion??? not sure tho?
Posted : 17/07/2012 10:59 pm
Test it, with it on, the suspension shouldn't bob, (as much) this is a good thing when you want efficiency, ie pedalling on the flat/uphill. That is what the extra damping circuit is for. With it off the shock is fully active, which is good when the going is rough and gravity is on your side so efficiency isn't priority no 1 but the wheel getting out of the way of stuff is.
Posted : 17/07/2012 11:05 pm
Always leave mine on the minimum setting on my 6 pack but then a good HL 4 bar doesn't bob.
Posted : 17/07/2012 11:07 pm
