what crank length?
[Closed] what crank length?
[#1730797]
I have a 29 inch inside leg (max). Should i get a 170 or 175 crank for xc racing?
Posted : 22/06/2010 10:43 pm
Won't matter.
Posted : 22/06/2010 10:46 pm
Oh I forgot.
Shortarse!
Posted : 22/06/2010 10:47 pm
farley buy a kids bike and have done! seeing as all your bikes have 175mm cranks stick with that. Its 5mm on a crank length, not like its 5mm on your cock 🙂
Posted : 22/06/2010 10:51 pm
thanks, i know i'm a short arse 😀
why won't it matter? advantage of one over the other?
Posted : 22/06/2010 10:52 pm
same difference rob 😉
Posted : 22/06/2010 11:04 pm
 mboy
With a 29" inside leg length, I'd recommend going for a 170mm crank. Shorter cranks will help you spin more easily. Though it doesn't make a massive difference.
Personally, even with 33" inside leg length, I prefer to run shorter cranks. It's more of an individual preference than a rule as to what you should run, but I think if you have got shorter legs, it's worth at least trying shorter cranks...
Posted : 23/06/2010 12:21 am
