New to the whole tubeless thing, and struggling with a track pump! What do I need to look for in a compressor? Any recommendations? Do I need to source a special presta adaptor?
Ta
Rich
I failed with a track pump recently, and someone from here suggested a CO2 canister [url= http://www.wiggle.co.uk/genuine-innovations-ultraflate-plus-co2-tyre-inflator/ ]thingamy[/url].
Worked a treat, if you press down the tire over the valve core, and then empty the can into the valve it pops the bead into the rim.
My top tip that's not failed yet if struggling with a track pump. Take out the valve core and then use the schraeder side of your pump and pump like crazy. Get some decent pressure in there and you should be able to remove the pump and stick your finger on the valve tube without losing much pressure then same again to get the valve in. Basically, without the core you can get air in much quicker.
2nd remove core.
Don't shell out for a compressor, ****g hell. It's a bike, not a hot air balloon. What rim are you using? A track pump inflates UST tyres on mavic rims nae bother - no need for a compressor, done it 100s of times. If it's Stans or something else then maybe more difficult, but still doable with tips like the one above.
Another tip if it's being a real bastard is to put an inner tube in and fully inflate till the tyre seats, then deflate and unseat on one side. Take the tube out that side and you'll then be able to get the tyre inflated and seated with one side already done.
Stans Crest rims, yellow tape. Racing Ralph non UST. Already done the tyre trick for one side....will try the valve core thingy next!
[url= http://www.singletrackworld.com/2011/04/how-to-go-tubeless/ ]Have you watched the video STW made with Oli?[/url]
Careful of CO2 - we tried it and it froze the latex!
I've seen things posted things about CO2 and sealent.
Unless I did it wrong, I put the tire on the wheel, used CO2 to get the bead onto the rim, then removed the valve core to add the sealent.
I don't see why you'd have sealent in the tire before it's on the rim....
Non IST tyres is your problem.
I use crests also. My tip is try spreading the tyre over the valve area to its seated position by hand. Then use light pressure with one hand while pumping with the other.
I like the valve removal idea i will try that next time.
Pawsy_Bear - Member
What is it about UST tyres that would make it easier? (Genuine question!)
Well unfortunately I gave in & bought a compressor, as fitting tubeless was too hit & miss for me with a track pump.. One of the lidl ones does me, aldi were selling the same thing a couple of weeks back (check your local stores for stock), bit loud but it does the job. Aldi also sell lots of attachments so you can use it for more than just blowing up tubless tyres
http://www.singletrackworld.com/forum/topic/ghetto-tubeless-inflator-total-cost-9p
Ghetto compressor...
