What commuting / cy...
[Closed] What commuting / cyclocross tyres?
 ajf
[#1652581]
New job means I am back on the bike for getting to work. Will be riding the cross bike but want to change the tyres from the existing road ones to cyclocross ones so I can choose a few different options on the way home.
Bearing in mind light, cheap, strong, choose two, I am only really looking for cheap and strong.
I would quite like it to be a reasonable tyre on both canal path / smoothish trails and on roads. It doesn't however have to excel at either.
Any suggestions?
Posted : 28/05/2010 3:01 pm
Schwalbe Marathon+ in 28mm or bigger. They'll probably last longer than you......
Posted : 28/05/2010 3:03 pm
Unless it's a short commute I'd buy something light, it would do my head in to commute on sluggish tyres!
Posted : 28/05/2010 3:05 pm
I love my speed kings but they wear in about 2 months if you do a lot of tarmac. I've now got 2 wheelsets, one with slicks and one with speed kings for the more off-road jaunts.
If I only had to have 1 set of tyres though, I'd still get the speed kings as they are fast rolling on road and great off road and I get cheap Contis...
Schwalbe Landcruisers, have central ridge so rolling is OK, tread either side for CX'ing it up. The central ridge isn't just a plain band though, so less sketchy than normal 'hybrid' tyres.
I use a fair amount of easy offroad on my normal commuter slicks though, you just have to be careful in the loose.
Posted : 28/05/2010 3:10 pm
I found speedkings awful. They let go if you try to crank them over any, get knobbles ripped off them, wear out pronto and the set I had kept blowing off the rim left, right and centre. Rim is an open pro - hardly rubbish! Managed half the HONC on them before having to gaffa them to within an inch of their life, I was running out of tubes!
Posted : 28/05/2010 3:12 pm
 ajf
Not fussed with light tyres as I have a set of road tyres should I want to do that. Commute at it's shortest would be 4 miles.
Looked at the conti speedkings but my opinion of the MTB based version isn't great. Saw them cheap @ on-one but resisted.
Anyone tried schwalbe land cruisers?
Posted : 28/05/2010 3:15 pm
I'd go for a 25c road tyre for that, TBH.
In fact, I run Vittoria Pavés as my commuting and winter road tyres (same bike) and was only riding them off road the other day. 24c, btw.
Posted : 28/05/2010 3:21 pm
 ajf
@ anotherdeadly hero - My normal road tyres are 23mm and don't fancy off roading on them at all. I am sure they would survive but I am not sure I would. I am tempted by the land cruisers though, was hoping for a few more to think about though.
There was some specialized I saw that had a similar tread to 8 blocks but cannot remember tyre name?
edit: maybe I am just a wuss then as others seem to use bald thin road tyres? Can't be much fun though?
Posted : 28/05/2010 3:22 pm
Hi AJ, how the hell are you?
I use Landy's on my cross bike. They've styed on pretty much since last years 3 Peaks. They do the commute just fine.
Posted : 28/05/2010 3:34 pm
"There was some specialized I saw that had a similar tread to 8 blocks but cannot remember tyre name?"
Specialized Houffalize. good tyres for what you want too!
Posted : 28/05/2010 3:40 pm
 ajf
Ah Mr Sparkle, okay cheers. 🙂
Fell running has been parked for this year as I try to sort my ankle out so just glad of the biking really.
Hows tricks over your way? Just had a look again at your CX bike in other thread. Them landies are chunkier than I thought. Which is good!
Kenda small block 8's here... they roll well enough and a fairly grippy. Don't know how long they will last, only done the one ride on them.
Posted : 28/05/2010 3:50 pm
marathons
Posted : 28/05/2010 3:56 pm
32mm small block 8's on mine, light and fast and grippy enough in the dry.
Posted : 29/05/2010 8:15 am
[url] http://www.chainreactioncycles.com/Models.aspx?ModelID=24615 [/url]
These are what I use daily in the 30mm, cheap, strong enough, not bad on the road and surprisingly capable off road.
Posted : 29/05/2010 9:57 am
