What cheap 100mm-is...
[Closed] What cheap 100mm-ish travel Forks?
[#6796801]
I'm sure these sort of things cause all sorts of problems within the STW brain trust.
I'm looking for some value for money forks for my Wife's bike.
http://www.thebikelist.co.uk/gt/avalanche-3-0-disc-hydro-2010
It's got some Suntours on it at the moment, they seem to weigh a tonne, they don't compress much and damp less - they might work better with a bit of TLC, but frankly it's only ever going to be so much glitter to roll them in.
Any recommendations? They don't have to be Rampage spec, far from - I'd like 100m-120m travel without upsetting the geometry too much (they seem long for their given travel) air sprung with a rudimentary but consistent damper I can at least set the rebound on.
I know nothing about short-travel forks.
No more than £200 really, second-hand isn't a problem.
Posted : 21/01/2015 11:06 am
I went through something similar when wanting to replace the Suntour XCR's that came on my bike in an attempt to shed some weight.
I got some great 100mm Rockshox Reba Dual Air off the classifieds here (posted a wanted ad) for well within your budget. I lucked out in as much as they were barely used.
I also looked at the SIDs which are lighter again, but unsurprisingly more expensive and harder to find.
Posted : 21/01/2015 11:17 am
Thanks, they look like just the thing - now just to explain to Mrs. Jay thay they're better than the iPad mini she wanted ha ha.
Posted : 21/01/2015 11:31 am
Some really good condition s/h Rebas will be well within budget.
Actually, you should have oodles of choice, 26" & 100mm is an unfashionable and unloved niche nowadays.
Posted : 21/01/2015 11:34 am
AllTricks have some bargain DT Swiss that would work lovely. You'd beed a new lower headset cup though for the tapered fork.
http://www.alltricks.com/mtb/forks/forks/dt-swiss-fork-xrm-single-shot-26-100mm-axle-9mm-tapered-white-131-132633.html
Posted : 21/01/2015 11:35 am
Win !
Not even worth buying second hand at that price.
Posted : 21/01/2015 1:26 pm
I got some Rockshox 30 Gold solo air from Merlin cycles last year £194 they are brilliant. Went from Suntour xcm and the difference is excellent.
They look good - I standby to have egg on my face... but I don't think there's a headset in the world that will allow me to fit a tapered fork to a 1 1/8th frame though is there?
Posted : 21/01/2015 1:32 pm
Is it not a 44mm headtube which currently has integrated cups, so by fitting an external lower cup you can then use a tapered fork?
e.g http://www.chainreactioncycles.com/nukeproof-warhead-headset-bottom-cup/rp-prod124574
The EX 44-40 B5 model
Posted : 21/01/2015 2:29 pm
Have a look on bike-discount.de. They've got Rockshox, Fox and RST forks - all (some considerably) under £200.
Posted : 21/01/2015 2:53 pm
You'll get some great 2nd hand forks for that money. I have a lovely pair of Fox, you'll even have some money left for flowers & chocolates.
Posted : 21/01/2015 3:33 pm
I have some rather lovely 100mm SIDs that I'd take £100 for. Would they be of any interest?
Posted : 21/01/2015 4:33 pm
Don't get anything that is Rockshox TK compared to modern dampening that stuff is just shit.
Posted : 21/01/2015 5:06 pm
munrobiker, I might be. what colour and QR? straight steerer?
Posted : 21/01/2015 5:08 pm
When upgrading the suntours on my hardrock I got some lovely Rockshox Recon Gold (the top end ones - not the TK!) and they were £200 three years back. Sure you'd find them cheaper by now. Likewise Rebas would be nice and I imagine in budget.
Edit, just found these http://flatoutcycles.co.uk/rockshox-reba-sl-100mm-q-r-1-1-8-forks-34567?fee=5&fep=8957&gclid=Cj0KEQiAuf2lBRDW07y3z6f96awBEiQA0IngJv5dqgtB7yxR84Ydc00vxcb7-Tfyw66nce9cmHv4dckaArdJ8P8HAQ
Posted : 21/01/2015 5:19 pm
It looks like the bike has a zero stack headtube
does that mean its a 44mm, if so yeah you can use one of them ^^^ headsets to run a tapered fork
Posted : 21/01/2015 5:31 pm
Sorry to jump on the thread but are you saying if you have a 44mm headtube you can use an external lower cup to make it taper steerer compliant? Could be good news.
Posted : 21/01/2015 6:33 pm
I'd stand corrected but a 2010 bike of that spec is surely going to be a 1 1/8" headset top and bottom. No?
Anyway, I have some suitable (assuming the headset is as I think) Marzocchi MX Pros in the garage doing nothing. They have rebound adjustment and lockout and can be run very soft. They are black though. £60 posted.
Posted : 21/01/2015 6:47 pm
ollybus - Member
Well you have 9mm QR hub so tapered wouldn't help you that much either in performace or in choice. Tapered QR fork is bit a pit pointless, why have a stiff upper chasis if the lower is like a noodle.
Posted : 21/01/2015 7:02 pm
