What Chainring?
[Closed] What Chainring?
[#2015928]
I am after a 32t middle ring, but my question is what one that will last me a while over the winter (and is cheap, not XTR prices)?
I have a FSA that has lasted me about 200mi on my On-One and a Race face one the Giant that has lasted me about 500mi. But Saying that I was using the squirt stuff and I think it didn't do its job to well (now gone back to finish line wet lube) so I think the lube wore the rings down quicker than is should have done and I am now getting really bad chain suck, but the mileage stated here may not be a true indicator.
Posted : 22/09/2010 3:55 pm
Middleburn with Hardcote is worth a punt for the price.
Posted : 22/09/2010 3:56 pm
200 miles isn't long! You could try a steel one for longevity, otherwise the Alu ones will all wear at a fairly similar rate.
The Shimano XT one is steel with composite to keep the weight down, but is quite expensive. Surly do stainless steel chainrings too.
Posted : 22/09/2010 3:59 pm
is there a way to fix the chain suck with the aid of a file? the gears arnt sliping.
if so do i file the trailing edge or the leading edge?
Posted : 22/09/2010 4:01 pm
LX one is steel
Posted : 22/09/2010 4:25 pm
Nesbo, file off the hook that starting to form, from whatever side it is...
Posted : 22/09/2010 4:36 pm
suggest cheap steel deores... all i use
paul
Posted : 22/09/2010 5:53 pm
