What chain tugs for...
[Closed] What chain tugs for a 456 carbon singlespeed?
[#2483978]
Read something on the onone website that the normal chain tugs for their swap outs don't fit the carbon 456.
Is anyone using chain tugs on a singlespeed 456? If so what?
Posted : 19/02/2011 12:07 am
I was about to ham-fistedly plough in with a recomendation to use a solid-nutted axle instead, but probably not wise on a carbon frame.
Posted : 19/02/2011 12:12 am
takisawa2: it has aluminium swap outs so bolt up would be fine.
mtbtomo: Is it possible to run a chain tug on the inside of the drop out instead?
Just spotted these as DMR have swapouts too: http://www.chainreactioncycles.com/Models.aspx?PartnerID=79&ModelID=216
Posted : 19/02/2011 12:25 am
scroll to bottom: http://www.singletrackworld.com/forum/topic/my-new-carbon-456-build
DMR ones I linked to by the looks of it.
Posted : 19/02/2011 12:30 am
Cheers, had a look at the DMR ones and will probably go with them.
Can't use a nutted axle cos I don't want to change the hub and I don't think they do nutted axles for Supperleggera hubs?
Does any one have a problem using QR's on singlespeed slotted drop outs or will they slip without a chain tug?
Posted : 19/02/2011 12:38 pm
if you use shimano QRs you should be alright. All others I would use a chaintug.
Posted : 19/02/2011 9:11 pm
