What chain length??
[Closed] What chain length??
[#5412350]
Hi all,
I have a Works 32 tooth chain ring 11-32 cassette sram X0 Type 2 rear mech and 112 Link KMC chain.....question is what length chain do I need to run it without a device and the clutch mech if you have any experience or can I just fit it as is?
Thanks guys!
Posted : 11/08/2013 5:21 pm
[url= http://sheldonbrown.com/derailer-adjustment.html#chain ]null
Posted : 11/08/2013 5:56 pm
Some work to a rule of big + big not through RD + 2 links, others wing it.
I winged it last week and it worked. Fit the chain with the quick link though the mech and see what it's like. In big cog at back the mech cage wants to be pretty stretched forward but not to the point where it's horizontal. In the small cog there needs to be a bit of tension left in the chain, ie it needs to be pulling on the mech cage slightly and the chain doesnt want to be loose at all.
If running on a full suss don't forget to collapse the shock and see if that has any bearing on it and adjust accordingly. The beauty of a KMC chain is that you can fit it at full length with the link then just shorten it by two links at a time until its right
Cheers robarnold will have a go and see!
Posted : 11/08/2013 9:57 pm
