What brake post mou...
[Closed] What brake post mount adapter do I need?
[#6345160]
I have a fork that as standard accepts a 180mm rotor on a post mount. I want to fit a 203mm rotor and cannot for the life of me work out what mount I need to fit it?
Posted : 16/07/2014 6:58 pm
What fork? Some, like the x fusion slants 2013 don't require one.
Posted : 16/07/2014 7:00 pm
Fox 36 2015. I can bang a 180mm rotor on it and it will be fine but I want the 203mm on. It does need a adapter, I just don't know what!
Posted : 16/07/2014 7:10 pm
Hummm, then what brakes? Maybe you just need a Shimano or whatever 203 post mount adapter?
Posted : 16/07/2014 7:18 pm
 DanW
Surely just a 20mm Post to Post adapter or am I missing something? So since your fork mounts fit 180mm rotors directly then a 180mm Post-Post mount adapter (i.e. it the adapter is normally 160 + 20mm = 180mm hence the name, but for your fork will be 180 + 20mm)
Posted : 16/07/2014 7:24 pm
I tried the 180mm adapter but it does not work as the disk is 203mm not 200mm.
Posted : 16/07/2014 9:30 pm
 DanW
Most adapters come with some washers. Just run 1.5mm worth of washers underneath the adapter to raise it slightly.
Posted : 16/07/2014 10:07 pm
You'd need a 183 post to post adapter if your fork is a 180post mount as standard as you need 23mm lift to get from 180 to 203 the same as post mount fork going 160 to 183..
Hope do em..
[url= http://www.chainreactioncycles.com/hope-post-to-post-disc-brake-adaptor/rp-prod13728?utm_source=Google&utm_medium=Shopping&utm_name=UnitedKingdom&gs=1&gclid=CLfk6Yrmyr8CFa2WtAodPjoAKA&gclsrc=aw.ds ]Like this [/url] the 183 version not the 203 one as that'll lift it 43mm not 23mm as they're for 160mm post mount forks as standard
Posted : 16/07/2014 10:39 pm
^Thanks I have just ordered one.
Posted : 17/07/2014 12:21 am
http://www.chainreactioncycles.com/shimano-mount-adaptor-front-post-to-post/rp-prod13747
Am I missing something? Surely you just need the standard 203mm post to post as per linky ^
Posted : 17/07/2014 8:25 am
You're missing the fact that the standard post mount 203 adapter is for a 160 post mount fork and the OP has a 180 post mount fork
Posted : 17/07/2014 9:35 am
