im needing to extend my rear brake hose, to try and use some titec h bars, instead of normal risers. ive got [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=4707 ]this goodridge kit[/url] in my garage.
unfortunately its only got a diddy piece of hose with it. in fact it even looks shorter than a front brake!! so i need some more.
can i use any hydraulic hose with this kit, or does it need to be goodridge?
at the mo, ive got 1300mm length, so im thinking i probably need 1400mm?
im thinking if i order online, itll be by the metre, so 2m length. can i cut it with normal cable cutters?
or am i best just popping into LBS and asking for 1400mm of hydraulic hose?
cheers
anyone?
I'd have though any of the goodridge hoses would work.
Like this one: [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=2938 ]hose[/url]
Any of the goodridge hoses will work, but I'd have reservations about other brands. It might work but I don't know what the liner is made from or the internal diameter.
Make sure you have VERY sharp wirecutters though and if possible use something to stop the hose being squashed. I use a small piece of brass pipe that it fits nicely inside to support it while cutting. Or buy some hose cutters.
ok thanks. goodridge it is 🙂
