Need to get a brake adapter but which one. The frame is post mount and the brake - hope mono mini is international standard. For a 160mm rotor
Ah.. what you need is a post mount to IS adapter for a 160mm rotor.
Make sure you get the right one for front and rear.
Actually, that'll learn me to be a smartarse. Something more like this
Fitting IS to post is a bit trickier, you might have to go up a rotor size.
That looks like it would work. Is there a cheaper adapter or to a 160mm rotor
Or try this one
https://clee-cycles.co.uk/P1043/product
It has good reviews and you dont necessarily have to go up a size. Just depends on what size post mount you have. I have not used one though so cannot comment from experience
