What B+ ish wheelse...
[Closed] What B+ ish wheelset?
[#7600530]
30 - 35mm ID would do me I reckon, JRA have WTB i35 on hope pro4s for 440.
Anything else worth a shout?. Cheers.
Posted : 24/01/2016 10:37 pm
Thanks, but looking for full builds George.
Posted : 25/01/2016 7:26 am
If you can hang on a couple of weeks i''ll have a pair of i45 front i35 rear built on pro2 evos for sale.
Less than 6 months old.
Posted : 25/01/2016 8:15 am
Sounds good Stu, let me know when you're ready, email in profile.
Posted : 25/01/2016 9:05 am
Will do.
Posted : 25/01/2016 10:33 am
Hi Nobeer
I am currently testing Halo Vapour wheels and they are very impressive. £299 a pair with bolt thru options. 30mm internal diameter and 35mm external. The hubs seem pretty damn good too. I am running them with 3.0 Nobby Nics and they are proving to be an outstanding Lakes wheel and tyre combo. 😀 I think they are excellent value for money and have proven to be very tough. The additional grip compared to my previous Hans Damffs on Mavic rims is astonishing.
Hope this helps?
Sanny
Posted : 25/01/2016 7:23 pm
Kind of OT but do these narrower rims work well then? 30mm id is more or less what I'd choose for a 2.3, I'd assumed b+ would need more but then, I know nothing about b+...
Posted : 25/01/2016 7:33 pm
I can vouch for the 30mm internal diameter Halo Vapours working really well with both 2.8 Rocket Rons and 3.0 Nobby Nics. They aren't quite as big as wider rims (obviously) but the level of grip is phenomenal and with the Nobby Nics, they measure up not far off the diameter of a 29 Mavic rim shod with a Hans Damff. The weight is virtually identical! Put it this way, I feel no need to switch back to the 29er set up. They roll extremely well too. I decided to try them as a test piece to see how easy it is to switch from 29 to 650b+ and whether it is a worthwhile thing to do. Hell yeah! 😉
Posted : 25/01/2016 7:48 pm
I'd be interested to hear how you get on with 40-45mm internal rims vs 30mm Sanny.
Posted : 25/01/2016 8:10 pm
Sanny, cheers fella, that's a great option.
I was tempted to go for something like 30-35 to allow either 3.0 purges or 2.8 NNs to fit into the pikes. It's for my 29er spectral, I reckon BeePlusFullSuss could be awesome!. 😆
Posted : 25/01/2016 8:36 pm
Alright silly old man!
The Nobby Nics on the Vapours measure up wider than Dirt Wizards on 50 mm rims. I would struggle to go bigger than the Vapours on my full sus Turner as clearance could become an issue. I've been ragging them in the Lakes for the last three days and they just keep impressing me. I'm running the pressures fairly low and they do an admirable job of coping with wet Lakeland off camber slabs and are a bit of an eye opener on roots.
Nobeer
If you fancy showing me your trails, I can come down and let you try them if you want on your bike? They fit in Fox 34 forks comfortbly. Not sure about Pikes though. E mail in my profile. 😀
Sanny
Posted : 25/01/2016 8:43 pm
Thanks for the offer Sanny, but a gubbed knee looks like it's gonna keep me off two wheels for a while. A couple of guys on the big 650B+ thread have the same set up, and fits fine.
Oh, and I let a mate borrow my spectral for the puffer, and he's broke a few bits! 😆
Posted : 25/01/2016 8:51 pm
I get that Sanny, but it's still just a trail bike rim width as NW says.
DW is a small tyre - a 2.5 Minion is similar in size on a comparable rim.
Try it on a dedicated rim (and a dedicated bike?) for the sake of comparison. The additional support and achieving a tyre profile as the brand intended should both make significant differences.
What pressure are you running?
Not trying to piss on your chips - I just feel you could get an even better set up.
Posted : 25/01/2016 8:55 pm
Nobeer - you surprised? Dave's a clumsy twunt! 😉
Posted : 25/01/2016 8:56 pm
Darn tootin!
Posted : 25/01/2016 9:10 pm
I decided on halo vapour35s on hope pro 4 rims and spech tyres after going back and forward for ages
Posted : 25/01/2016 9:18 pm
Northwind - Member
Schwalbe recommend 40mm to 50mm. Trailblazers were always marketed with the i45.
Think you take recommendations with a pinch of salt though. Ive run 2.4 Nics on 21mm Crests for years, never burped once. Do you realky need [i]twice[/i] the width for 2.8?
Posted : 25/01/2016 9:33 pm
If that's what the tyre is designed for, then ideally yes. Your 2.4 tyres were likely to be designed for rims up to 25mm as that's all that was around.
Posted : 25/01/2016 9:58 pm
Expermentation is going to be necessary I think. The Schwalbe 2.8 tyres are very different beasts to the 3.0s. Its hard to believe that they would be both best suited to the exact same rim size.
Posted : 25/01/2016 11:03 pm
http://singletrackworld.com/forum/topic/650b-and-other-plus-sizes-if-you-like-rim-tyre-frame-fork-combinations
2.8 is fine with my 25mm internal rims. I think I'll go for a 35mm internal one for the front to widen the front tyre a little more.
Posted : 25/01/2016 11:16 pm
Hi Sillyoldman
Are you in a habit of pissing on your chips? Must be a Dundonian thing. I like salt (from sea water and not my own water) and vinegar personally! 😀
I'm running between 15 and 20 psi depending on how rocky the terrain is.
As for getting to ride a proper 650b+ dedicated machine, if you know anyone in the industry who could help with that, that would be grand! 😆 A new Genesis would definitely help me with putting your sage wisdom into practice. 😉
Posted : 26/01/2016 1:00 am
[quote=Sanny ]As for getting to ride a proper 650b+ dedicated machine, if you know anyone in the industry who could help with that, that would be grand!Might be a bit wee for you Sanny but let me know if you fancy a shot
[url= https://farm6.staticflickr.com/5738/22982613400_5594492235_b.jp g" target="_blank">https://farm6.staticflickr.com/5738/22982613400_5594492235_b.jp g"/> [/img][/url][url= https://flic.kr/p/B1TUgb ]DSC_0331[/url] by [url= https://www.flickr.com/photos/druidh2000/ ]Colin Cadden[/url], on Flickr
Posted : 26/01/2016 1:07 am
benpinnick - Member
Is there that much difference? I went 2.8 'cos I wanted to fit in a standard Pike and still use a marsh guard
Posted : 26/01/2016 11:48 am
Yeah quite alot. If you ignore the tread pattern you'd probably have given them different names! The 2.8 is bascially a 2.8 tyre. Calling it plus is probably a bit of a stretch - it sizes up pretty much as you'd expect a 2.8 27.5 tyre too, 28 and a bit inches tall, 2.8 wide etc. The carcass is fairly tough like a middle of the road trail tyre too.
The 3.0 is very different though. The actual width is the +5mm the sizing would indicate, with basically the same nobbles slightly farther apart - at low pressures I doubt the grip will differ, you're getting the same rubber on the ground on either tyre. The big difference is in the size and construction - by comparison the 3.0 is significantly thinner than the 2.8, more like an XC tyre kind of build than a trail tyre, its also alot taller, sizing up 10mm taller on the sidewall than the 2.8 version, giving it a more '+' like size getting towards 29er (its still not but its much closer).
Different tyres for sure. I would be interested to know more why Schwalbe went in different directions for the two sizes.
Posted : 26/01/2016 1:53 pm
That's interesting ben. cheers for the detail. I'm happy I went 2.8 reading that.
Wish my frame would arrive, have all the bits now except frame (and the seatpost, which is coming with). Really keen to give this a go.
Posted : 26/01/2016 11:44 pm
So, Stu can't sell me his wheelset yet, and those Halo wheels are out of stock until the end of march Sanny.
Owt else?.
Looking like JRA.
Posted : 04/02/2016 2:56 pm
Alpkit are doing plus size wheelsets, might be too wide for you but a good budget option. Dt Swiss, Easton and spank are bringing our new wider rims imminently.
Posted : 04/02/2016 3:03 pm
Alpkit ones are a bit hefty tbh, I'm by no means a weenie, but they're 500g heavier than the Halo wheelset.
Posted : 04/02/2016 4:41 pm
America Classic Wide Lightnings are worth a try, I've had them on my Whyte 909 for a few months and they've been great - I'd think they're plenty wide enough to run + size tyres. Nice and light too
Posted : 04/02/2016 4:54 pm
Looks like Triton have the Vapours in stock, that'll do!.
Posted : 05/02/2016 9:09 am
I've been running Roval Fattie Carbon SL's all last year at 30mm internal width, very pleased with the increased grip levels & how much the tyre looks to of increased.
I've been told the rim will take a fattie tyre I guess up to 3.0" but won't squeeze one of those in a Bronson frame.
No issues with them other than my clumsy riding snapping a spoke, would definitely have another set though I have a new pair of DT240 hubs itching to be built on to some tasty rims.
Posted : 05/02/2016 4:54 pm
Turns out 'in stock' doesn't quite mean that at triton.
So, ordered a pair of i35 rims and novatec hubs, and I'll get a local wheel builder to do the business. 35mm internal should give a nice profile, good sidewall strength and less chance of burping.
Really looking forward to trying them out now, the NN 2.8's came, look a really nice option for muddy stuff too, nice square knobs on em.
Posted : 05/02/2016 9:55 pm
I could have put money on that happening!
Everytime I've ordered an 'in stock' item from Triton I get a phone call telling me they don't have it.. in stock.
Posted : 05/02/2016 11:46 pm
Interested to see how you go with this, I have a spectral 29er too! Please post pics and results!
Posted : 06/02/2016 12:43 am
Will do fella.
Posted : 06/02/2016 8:00 am
phy7tes - Got the wheels yesterday, 2.8NN's went up tubeless no issues on the i35's. Loads of room on the Pike, no probs at all, but maybe a little too close for comfort on the rear.
Loads of room at the seatstays, but the chainstay on the NDS may be borderline - Pretty impossible to measure this as it sits a fair bit lower than it's DS opposite number.
BB height feels okay, and measures up as being about 2mm lower than my SB66, so I don't really have any concerns there.
I've got some protective tape on there, and I'm planning to take it to Kirro/GT/Comrie tomorrow, see how it goes.
On the late night car park test, Nobby nics felt a bit self steery, but I think that may be just because I had plenty pressure in them to seal them overnight, we'll see.
If the back does rub, then it'll be back to 29er mode, and I'll keep the wheels for another bike as they're a really nice looking build - 110 for the rims, 100 for the hubs and 60 for spokes and build.
I'll get some pics posted up after tomorrows ride.
Posted : 19/02/2016 1:18 pm
I've just recieved a 3.00 NN and I already had a couple of 2.8's.
I really can't see or feel and difference in the thickness of the sidewalls.Looks like the same tyre but a bit bigger to me.
Were the 3.00's you had Trailstar or Pacestar? Maybe that makes a difference?
Posted : 19/02/2016 2:44 pm
Nobeer - how was the ride? Any rubbing?! Let's see these pics!
Posted : 25/02/2016 8:37 am
Aye, it's not happening on the rear, just not enough clearance at the non drive side mate, and there's only just enough on the drive side, so no point trying to dish the wheel over.
If you have a look at my instagram, you'll see some pics - @ringoffire.
I was out last night up the local moor, and there's a section that is perfect for testing out whether you are getting pedal strikes as it's really lumpy but pedally. Good news is that I didn't get any, and tbh the BB height was one of my main concerns.
I'll be trying something like 2.4 NN or Trail king in the rear, as the front end grip with the B+ is terrific.
Posted : 25/02/2016 9:12 am
Nobeer.
Try one of these in the rear.
http://www.chainreactioncycles.com/wtb-breakout-tcs-tough-fast-rolling-tyre-2016/rp-prod121850
Height wise it's only a fraction smaller than a 2.8NN but it's a bit narrower.
Works well in the mud too.
Posted : 25/02/2016 9:21 am
Doesn't look like it'll shed mud well though, does it? knobs are a bit close.
Posted : 25/02/2016 9:24 am
Thanks for the update pal, looks awesome, shame it doesn't fit though! Good work anyway. I'll be keeping an eye on your Instagram....
Posted : 25/02/2016 9:25 am
It's been working for me in the mud*. It's the tyre I fit when it's muddy and I need a bit more clearance.
*My mud may be made of different stuff to your mud. 🙂
Posted : 25/02/2016 9:28 am
You have it on a scraper don't you? Any chance of a measurement when you get a chance mate? It'll be going on an i35, so should be maybe a mm or so narrower.
Our mud is in Ayrshire, so it's generally runny wet! ie not claggy.
Posted : 25/02/2016 9:34 am
