I like the look of the M9020 cranks - but the cost of the replacement chainrings put me off and they are not a narrow wide system (anyone of any experience of these cranks?)
Race face next is too expensive (Budget is around £250)
Any other suggestions?
It's for my trail bike.
Thanks
http://www.pinkbike.com/news/trek-remedy-29er-justin-leov-crankworx-rotorua.html
If you look here they are running the M9020 crank arms with aftermarket bolts and NW rings it is much lighter. This generation of XTR crankset it a quite a bit lighter than the last.
[url= http://www.wolftoothcycling.com/collections/chainrings/products/96-mm-bcd-chainrings-for-shimano-m9000 ]Wolftooth Components [/url] do a 96mm BCD narrow/wide ring for M9000/9020, you can't use any ring. I suspect others will follow.
That would get my vote, or X01 (same cranks as XX1) with a direct mount ring.
edward2000 - Member
Of course!
That option is about 100-150g heavier than Shimano XTR or SRAM X01
Thanks frosty. So you're saying that these
will fit onto a shimano external bottom bracket? The description says its a BB30 and io thought that was different to shimanos offering?
Thanks for your help
edward2000 - Member
Thanks frosty. So you're saying that thesewill fit onto a shimano external bottom bracket? The description says its a BB30 and io thought that was different to shimanos offering?
You would need the GXP BB which is a bit heavier and have a poor reliabilty record compared to Shimano.
[b]XTR M9000 32t aftermarket rings [/b]
Crank arms 472g
Aftermarket bolts 8g
Aftermarket ring 50g
BB-70 93g
623g total
[b]X01 GXP Spiderless ring 32t aftermaket [/b]
Crank arms 473g
GXP BB 108g
32t spiderless ring 65g
646g total
You can get a hope GXP BB which is more reliable but with the Shimano you can just use the SLX/XT
