What 29er Light Bic...
[Closed] What 29er Light Bicycle Rims?
[#6735912]
Hi chaps,
Im after some Light Bicycle carbon rims to lace onto a soare set of pro2 evo hubs.
Id like them to be similar width to my flow exs.
Theres a lot of options, can someone point me at which ones i should be looking for?
Ricks
Posted : 29/12/2014 10:57 pm
There are 3 rims each with, I think, 2 iterations. I didn't think it was that hard really? There's effectively a light duty and heavy duty version of each rim.
Posted : 29/12/2014 11:49 pm
I opted for the 35mm Hookless rims, which I also built onto spare 32h Pro2 Evo hubs, with DT Comp spokes and brass nipples. Weight is 1700g, which is a fair bit lighter than Flows, which are around the 2KG mark aren’t they? No complaints yet in 9 months of (ab)use.
Posted : 30/12/2014 12:04 pm
Same build as yetiman here. Been very pleased with them. Only this I wish was better is their resistance to 'rock rub'. Mine are fairly heavily scratched.
Posted : 30/12/2014 12:07 pm
 DT78
Check your frame clearance to, a 2.25 tyre on the 30mm only just has clearance on my scale. (Which is admittedly a xc bike). Glad I didn't go wider.
Posted : 30/12/2014 12:37 pm
Same build as Yetiman too. Been plenty tough enough and noticeably stiffer and lighter than the Flow EX's they replaced.
Posted : 30/12/2014 12:42 pm
Is the quoted ERD accurate on these? Also, what weave do folk prefer?
Posted : 30/12/2014 12:54 pm
ERD was spot on. I went for the matte finish and UD weave to be subtle. Finish is the same as my Enduro Expert carbon frame and that was considerably more expensive!
Posted : 30/12/2014 1:19 pm
