What 26" forks...
[Closed] What 26" forks are people using for 650b wheels
[#7140269]
As title and what size tyres ?
I know Fox are generally compatable but what about the other makes?
Posted : 19/06/2015 9:57 am
X fusion slant work although you will have to fit a rubber stop to the internals for full 650b compatibility.
Posted : 19/06/2015 9:59 am
BOS work too, although I wouldn't be putting a tall tyre in there
Posted : 19/06/2015 10:34 am
Woah!, that's a sweeping generalisation. Older Fox 36s have space but I'm pretty sure the smaller forks don't have clearance between the crown and the tyre at full compression.
Posted : 19/06/2015 10:41 am
IIRC most pre 2013(?) can take a 650b wheel, before they changed* the brace. There was a forum on MTBR somewhere that explains this further.
*when they realised there was more money to be made 😉
Posted : 19/06/2015 10:46 am
good question
I've got 26er RS Lyriks 160mm 2012 - would these be compatible?
Posted : 19/06/2015 11:32 am
 br
[i]I've got 26er RS Lyriks 160mm 2012 - would these be compatible? [/i]
If you can't stick a fat finger between a 26" tyre/wheel and the brace, no.
Posted : 19/06/2015 11:47 am
