were to get shock b...
[Closed] were to get shock bushings from?
[#418383]
any good internet companies sell shock bushings?
Posted : 24/03/2009 6:51 pm
what bike
Posted : 24/03/2009 6:56 pm
Mojo, but do it online for free postage. You'll pay £3 if you order over the phone. You will need all the dimensions to hand as well.
Posted : 24/03/2009 6:59 pm
A decent bearing supplier. There's a code on them and it's a standard size DU bushing. Should be about £1 each.
Posted : 24/03/2009 7:27 pm
betd
Posted : 24/03/2009 8:48 pm
BETD Cycle components. I phoned the guys there, gave them my measurements and they told me what bike I had!!
Posted : 24/03/2009 8:51 pm
speak to dan at betd great fella.the hula hoop du bushes are exellent but do not get sucked into buying there ss hardware,this is expensive & lasts no longer than std alloy hardware,especially if your unlucky enough to have a shock in the firing line of the rear wheel .
Posted : 24/03/2009 11:26 pm
BETD,it's the only place to go..........
Posted : 24/03/2009 11:43 pm
Local bearing supplier, £1 a pop - going anywhere else seems madness unless you're not confident identifying the dims of your bush.
SS hardware from BETD has worked flawlessly for me.
Posted : 24/03/2009 11:51 pm
TFtunedshox. Always got it right for me, tell them the bike and the shock, they will send the correct bits.
Posted : 25/03/2009 12:16 am
cause they get it right its not rocket science it is shock specific, not bike specific ! its a 1/2 DU bush if its a fox, manitou and rockshox are different metric sizes £1 or so from a bearing supplier 🙄
Posted : 25/03/2009 1:12 am
righty - If it's the shock bushes they are different lengths bike to bike, i.e. a fox shock on a demo has different length (and type) bushes to fit the shock mount to say a fox shock on a heckler or stinky or a 224. If you are not sure about measuring it, call someone who knows. If you can measure it and know you are getting the correct thing a bearing supplier will always be cheaper. A Tftuned kit is so much easier though. 😉
Posted : 25/03/2009 12:31 pm
Bushings (either nylon or metal) are specific to the shock. Reducers (or axles and spacers) are specific to the frame.
Posted : 25/03/2009 12:36 pm
as r3g says bushings and reducers are 2 separate things bushings you can get cheap from bearing suppliers.I've not yet found a cheap supplier of reducers tho- does anyone know any? ❓
Posted : 25/03/2009 12:58 pm
