So i just bought a shock pump and when i conect it to the schrader valve the gauge doesn't show anything but when i start pumping it begins to show some pressure. But its filling the fork with air . thansk p.s sorry for my englsih
You probably bought a lossless shock pump. It's designed like that so you get a more accurate pressure reading. A Topeak perhaps?
Ok thanks for your response . Its a giyo GS02D shock pump
How do you know it's filling the fork with air?
I had a similar issue a few weeks ago when a friend lent me a shock pump, the pump head was fouling on the fork before it had properly engaged on the valve - and it had exactly the same head as yours, I had to get a different pump with a slimmer head.
Where I have had this in the past it was where the air wasn't actually going into the shock. I'd check it was latched on correctly.
