Hi , am just cleaning / checking the bike after a long week of riding and found that the rear non drive side bearings where the seatstay meets the chain stay are loose where they sit in the frame . They move slightly under load from side to side , and after dismantling the frame I can push them out by hand. It's like the hole in the frame where they sit has become larger. Anything I can do? Ta!
What frame and how old?
A friend has had two replacement Trek frames through similar issues. The LBS dealing with it via the importer.
Norco aluminum sight from 2013
I'd contact the shop you bought it from or distributer to see if it is still in warranty
Loctite a new bearing in if it's not in warranty
I'd try one of the 600 range (638?) they are for fitting bearings
Cheers I'll give it a try
