Weird bb7 brake iss...
[Closed] Weird bb7 brake issue.
[#7169110]
Rode to the pool earlier and the back brake lever pulled straight to the bar. I hop off, wind in the cable adjuster and off I pootle. Braking is all fine.
On the way back from the pool, cycling down hill, all of a sudden my back brake locked on as I skid to a halt. This is rectified by unwinding the cable adjuster I wound out to the original setting and normal braking resumes.
So other than being haunted, wtf is up with the brake? I can't seem to get my head around what could be causing it.
Posted : 02/07/2015 4:24 pm
I found my heel clipped the rear adjuster when pedaling, causing the brake to eventually stick on, had to get different calipers in the end.
Posted : 02/07/2015 4:37 pm
 jeff
cable outer pulling out of the brake/lever and getting caught?
Posted : 02/07/2015 4:46 pm
