We done the shiftin...
[Closed] We done the shifting crankset?
[#7684621]
Quite clever really...
http://www.bikerumor.com/2016/03/02/first-look-vyro-amen1-a-shifting-crankset-alternative-to-gearboxes/
Posted : 03/03/2016 10:33 am
I saw that a few days ago when I was obsessing over gearboxes. It's clever but the bits that move would soon be covered in gloop chucked up by the front wheel 😕
Posted : 03/03/2016 10:50 am
Nice idea, however I don't think it'll be something that's economical to have as an alternative to a front mech, regardless of potential advantages.
one thing I do like from that though is the adjustable crank arm inserts.
Posted : 03/03/2016 11:06 am
This, front mechs work well enough, and cost <£20.
This is susceptible to being hit by rocks and costs????
Pinion gearbox (or similar), or Frame mounted rolhoffs are the way forward, even Honda's "mech in a box" makes more sense these days with big hollow carbon frames (a 10-42 might struggle to fit though!).
Posted : 03/03/2016 11:44 am
Yes, would not want to mash it against a log.
Posted : 03/03/2016 11:45 am
Suntour did this ages ago:
Posted : 03/03/2016 11:48 am
Looks like a cynic-al project 🙂
Posted : 03/03/2016 11:50 am
Hmm grit and crap getting into tight clearances in the actuation mechanism, cant see it being a long lasting device over here.
Posted : 03/03/2016 12:03 pm
You are still stuck by with all the dangly bits out the back so I don't really see what it achieves. I have a Rohloff which gives a wide gear range and no maintenance or dangly bits to break. That works well though it does add weight and a bit of drag. I think it would be even better if it could be mounted at the bottom bracket but as I understand it there would be torque issues if you tried that. They talk about combining it with a hub gear but you'd then need a chain tensioner which again takes away from the appeal.
I think the problem is that development began a long time before all these wide range cassettes began to appear which make a 1x set up more suitable for most riders.
Posted : 03/03/2016 12:06 pm
