water inside my fra...
[Closed] water inside my frame
[#814254]
ok so i have a 04 sworks enduro and have been riding in the rain and mud for a few days and washed the bike off last night
went out tonight to tweak brakes and lifted bike and heard a rush of water!! moved the bike from side to side and slosh slosh not good i thought looked over the frame and no drain points, so i dismantle the headset and forks and tip the bike forward.......out pours about a pint of dirty brown water.....How the **** did that get there??? and is this normal???
what should i do to stop this?
Posted : 25/08/2009 9:43 pm
I have a small hole at the bottom of BB, I guess this solves this.
Posted : 25/08/2009 10:15 pm
my old heckler and my Litespeed Ti obed used to do this. the heckler was worse.
i used to have to remove the BB to get the water out, the Ti was even worse for the fact it had a shimano BB and was a ****er to get out.
i know mine used to get down the seattube.
Posted : 25/08/2009 10:24 pm
ive read the bit on bike radar about drilling a small hole at the BB to let the water out but the Sworks frame has a lifetime gaurantee on it and would that not void it if i did that?
I think it may be a combination of seat post and head set ingress. Had a thought a pint of water can be pretty heavy think of the extra weight your carrying around maybe have to retune my suspension haha
Posted : 26/08/2009 10:09 am
The 02-04 enduros do this, my original 03 did! There are some holes behind the seat tower (above the rear shock) and also the seat tube had a hole inside it which let water in if your seatpost wasn't covering the hole.
Some copter tape cover the small holes and a longer thomson seatpost sorted the other.
You should be able to drain the water out of the screw hole for the cable guide on the BB shell.
Posted : 26/08/2009 1:11 pm
