Warranty issue- wha...
[Closed] Warranty issue- what would you do?
 hora
[#3221080]
Ok my high and low speed compression has packed up on my Lyriks bought new this Summer.
The warranty dept has informed me that they are out of the compression units until mid-November.
What would you do? Is it reasonable to speak to the bikeshop and say 'look you need to sort this' BEFORE then?
Posted : 07/10/2011 11:28 am
how?
Posted : 07/10/2011 11:29 am
 grum
Yes, they should just give you a new pair of forks. Although it's you so it was probably your fault anyway 😛
You can ASK the bike shop whether they have a means of resolving it but they are under no obligation to do so.
Posted : 07/10/2011 11:30 am
What on earth do you do with your forks?
I've owned about 20 pairs from all the major manufacturers and never had a problem.
Having said that - 6 weeks is too long I'd be looking for full replacement set of forks or a loan pair in the meantime.
Can't they just take a compression unit out of a pair they have in stock and then sort out the warranty replacement when the units are back in with fishers.
Posted : 07/10/2011 11:31 am
IMO 6 weeks is unacceptable to wait, surely fishers can do something in that time, loan set or whatever?
Posted : 07/10/2011 11:35 am
 hora
1. Coil Pikes - hydrolocked
2. 3yrs ago Uturn Lyriks - Moco leak (similar to this I imagine)- unit replaced.
3. Two-step Pikes. I really don't want to go there as I'll start rocking backwards and forwards.
I sucked it up and lived with it for the 4 week I had to wait (though my suipplier was in the US, so no spare for me), though I then spent a fortune on servicing/upgrading another fork to replace it, BUT had to wait as long for that to be returned too...
Luckily I had another complete bike to run.
This is why the n+1 "bikes to own formula" works 😉
Posted : 07/10/2011 11:36 am
Was that because you imagined them?
Posted : 07/10/2011 11:37 am
 grum
My coil Pikes wore down horribly around the seals and started leaking oil. Rockshox forks = not fit for purpose. Try Fox. 🙂
Posted : 07/10/2011 11:38 am
LOL @ Grum 😀
Posted : 07/10/2011 11:41 am
Mid-November? I wouldn't worry about it tbh. It'll probably take that long to sort out your warranty issue with your terrible turner frame.
Posted : 07/10/2011 11:48 am
 hora
The Turner frame isn't terrible. Who referred to it as that? I'd class it as intriguing whereas I'd class Santa Cruz frames I've owned as neutral. Is that fair?
Posted : 07/10/2011 11:56 am
I'd disagree with this, if the forks have been serviced to schedule then they would be expected to be fit for purpose, and to last an acceptable amount of time (they grey areas of the argument). It is the retailers responsibility to suck it up when things to go wrong (hence the sale of goods act).
Theres also the section of not being unduly inconvenienced in having the issue resolved (by the retailer) which 6 weeks would push in a normals persons opinion (what the act is judged by).
How you actually go about it is a different matter, rushing the shop waiving acts in the air and screaming for instant satisfaction would get anyones back up. Politely pointing out that you have spent a considerable amount with them, and as such they have a responsibility to ensure you are satisfied would be appreciated, and no doubt result in a happy / repeat customer.
Start with the latter and see what they suggest, start hinting towards the former if they start screaming their responses ...
Posted : 07/10/2011 12:01 pm
 hora
Its not my style in any part of my life to go around screaming, waving receipts and telling people they should serve me.
My missus has done that before and really really made me cringe.
Posted : 07/10/2011 12:03 pm
How do you manage to have so many problems with your frames and forks Hora? Talk about a run of bad luck...
Posted : 07/10/2011 12:06 pm
 hora
Only Rockshox and a first for a frame. 🙂
Posted : 07/10/2011 12:14 pm
You do realise that you have a weird form of munchausen syndrome by proxy, don't you.
There is absolutely no way on this earth that all the things you say are broken, actually are.
The only thing thats broken is your massive inflatable planet-head!
Have you looked at the Mico damper to see what's wrong. They're not hard to disassemble. Sometimes that shart in the middle is turned too far one way and becomes stuck. Freeing it isn't hard.
Posted : 07/10/2011 12:18 pm
 hora
That'd be a good idea but my idea of mechanics involves overtightening and a claw hammer so I don't really want to touch/void the warranty
Posted : 07/10/2011 12:21 pm
Posted : 07/10/2011 12:38 pm
Posted : 07/10/2011 12:41 pm
Posted : 07/10/2011 12:42 pm
Posted : 07/10/2011 12:44 pm
my high speed compression adjuster on my 66s broke off about 4 years ago, can't say I missed it.
just wait 6 weeks.
 hora
What even if you'd like to adjust your compression to possibly the best setting?
Posted : 07/10/2011 12:47 pm
Compression damping packed up? But you can still ride them?
One less thing to twiddle, more time to ride.
n+1 bikes should be defined as n including a rigid single speed just to be sure there's one working.
Posted : 07/10/2011 12:56 pm
 grum
For you it's probably best not to mess around with these things anyway. 🙂
Posted : 07/10/2011 12:58 pm
Are you familiar with Hora's track record? He can/does break everything
Posted : 07/10/2011 1:23 pm
Posted : 07/10/2011 1:25 pm
 hora
After Fishers response to me I'm off back to Fox. At least the ****ing things work. Stopa if you read this I bet your laughing like a drain 😐
Yes- why did I trust another Sram/Lyrik product? Fox is the only way.
Posted : 07/10/2011 1:38 pm
You are aware, my balloon-headed friend, that Fox need servicing more often than anything else out there. With your track record, I'll give 'em a week
Posted : 07/10/2011 1:50 pm
 hora
Get the open bath ones, bit of oil around the stanchions after every ride- cycle them, wipe clean and jobs a good un.
Posted : 07/10/2011 1:51 pm
hora - get some of the new Marzocchis - 3 year warranty and no servicing.
Posted : 07/10/2011 1:52 pm
Rigid forks?
Posted : 07/10/2011 1:56 pm
 GW
Just ride them until Fishers (or whoever?) have the spares in.
we all managed just fine for years without any compression damping at all nevermind hi and low speed adjustable compression damping.
Posted : 07/10/2011 1:57 pm
Imagine the damage you'd do to a set of forks if you actually rode them, instead of just constantly swapping them from one frame to the next
Maybe that's the problem? 😉
Posted : 07/10/2011 1:58 pm
^ this.
Posted : 07/10/2011 2:01 pm
 hora
Ontop of not being able to get the last 1/3 of travel.
Question is- why should I have to wait until mid-Nov at the latest for something that cost me £500 two months ago?
Would you suck that up? Maybe I've got a different perception of service levels that you should expect?
Would you wait that long for a car part for your car under warranty?
Posted : 07/10/2011 2:04 pm
Because is is the 127th pair of forks you've returned to them as a warranty claim, and frankly they're sick of the ****ing sight of you?
Jus' sayin like....
Posted : 07/10/2011 2:10 pm
[i]Would you suck that up? Maybe I've got a different perception of service levels that you should expect? [/i]
No, don't accept it.
Your contract is with whoever you bought them from - it's down to them to sort it out.
I'd start with them and explain you're epxecting to ride your bike int he meantime and what can they do in terms of either replacement or loan forks as the ones you have are clearly not fit for purpose.
One quick Q: have Fishers actually got hold of the forks and confirmed your diagnosis of the problem or are they workign on your 'it's broke and needs replacing' diagnosis?
Posted : 07/10/2011 2:12 pm
I though you always had spare forks?
Posted : 07/10/2011 2:14 pm
Hora - You know those mentally unstable care-in-the-community cases that go in and confess to murders they didn't commit? And the police take a statement off them just to humour them?
Thats how every bike shop views you. Jus' sayin like....
Posted : 07/10/2011 2:17 pm
