Warmer insoles
[Closed] Warmer insoles
[#10299404]
My venerable Lake winter boots have a warm and waterproof upper, but those daft Yanks forgot to make the sole warm and cut a big old hole in the bottom to access the cleats. They are bigger than my normal shoes, lots of volume.
I've put in a double layer of tinfoil under insole, and that has improved things.
Insole is worn out, so please suggest a warmer insole - I'm tempted to just put a layer of karrimat in there.
Posted : 29/10/2018 8:43 am
What sir needs is a pair of lambswool insoles;
https://www.eccoshoesuk.com/ecco-lambskin-insoles/p606
Had these in my cycling shoes when I used to commute through winter. Toasty warm .
Posted : 29/10/2018 9:42 am
Just got these: great so far
https://www.sportpursuit.com/remote-controlled-heat-insoles-red
Posted : 29/10/2018 9:55 am
Random thought.. Odour eaters insoles are rubber on the bottom with the top layer being a spongey material, might be worth a punt for a fiver?
Posted : 29/10/2018 9:58 am
 ton
I use alpaca ones mate.  £9 a pair on line
warm as toast
https://www.thealpacashop.uk/Alpaca-Insoles-Natural-Colours
Posted : 29/10/2018 10:45 am
Ton  -  How do there insoles perform once they get wet?
Posted : 29/10/2018 11:06 am
^ same here, I don't think wool will dry/survive long...
You are right, an odour eaters cheapy from suitable budget retailer would work.
Posted : 29/10/2018 11:37 am
 ton
warm wet wool insulates.    ask sheep and other flurry things
Posted : 29/10/2018 11:42 am
