All,
I'm looking to put a wall mounted stand in my garage, however as space is limited I was trying to find one that released and swung flat against the wall so you could just flick it out when you needed it. That Park ones both seem (?) to be fixed sticking straight out all the time. Anyone know if such a thing exists ?
no but surely easy to make with a large hinge
The clamp on the Park (PRS-4W) slides out to leave just the wall mount, which sticks out 14cm.
Hmmm that's what I thought, would be nice if it was hinged instead of pull out.
http://www.ribblecycles.co.uk/sp/road-track-bike/S900-Wall-Workstand/BOSSWORK180000000000
Something like that? I've seen it under a few different brand names
(for the PRS-4W) Even if you weld the mounting plate to a hinge, the whole thing is still going to stick out by 10cm because of the depth of the clamp.
spev - yep that's what i want. Online from Ribble - price good, ahhh $105NZ delivery .... oh dear.
Does no one in NZ do the same thing in a different brand? Is it expensive because of import duties and taxes? Royal Mail say £28 for a "Small Package" by AirSure
Nah not that I can find unfortunately. Will have a deeper hunt via LBS. Yeah the delivery looks insane - its probably not that heavy and we post stuff backwards and forwards all the time. Barstewards.
EDIT: Talking out my derriere as have now found exactly what i want about 1k from the house. Thanks all you proved they existed 🙂 http://www.burkescycles.co.nz/prod/e612/sta8010.html
A few years ago I had one of these set up, not a sturdy as a full workstand but fine for general tinkering duties. It does get in the way of under the top tube cable routing and is tricky with some suspension designs but it did the job for me until I worked up an alternative;
[img]
[/img]
http://www.bikecare.co.uk/acc/cyclestands.html
there is this -
http://www.southwatercycles.com/products.php?plid=m7b166s168p25466&rs=gb
but I have one of these bolted to the side of the shed and its great, been left out in all weathers and it still works fine - http://www.chainreactioncycles.com/Models.aspx?ModelID=10228
(edit thats exactly as linked to on the NZ bike shop site above. I can recommend it highly, very solid)
halfords did one similar that folded too. It's only difficult if you take a wheel out and kick out the centre of balance
