Wahoo and Garmin mo...
[Closed] Wahoo and Garmin mounts
[#10107024]
Will a Wahoo cycle computer fit on a Garmin Out front mount?
Posted : 23/07/2018 12:02 pm
 Bez
You need to rotate the actual mounting bit 90 degrees (most/all allow this, but check) and snip about half a mill off each of the lips with a knife. (The mount still works with Garmins when you rotate it back. Unless you somehow tits it up spectacularly, but it's an easy job. Plenty of videos on the 'Tube if you're in doubt.)
Posted : 23/07/2018 12:13 pm
