hello, anybody had any joy finding a suitable mount for an element bolt on mtb bars? not too keen on paying 50 quid for the k edge one, thanks.
Barfly mount can be had for £35 and includes adapters for all computers/gopro.
K edge top cap mount perhaps?
I just use the circular one that comes in the box that you zip tie to the bars, works well as it means the 31.8 mount is on the other bike permanently.
i have a oneup EDC so a top cap mount is out
+1 bar fly mount. Come with a shim too if you need to swap bars. Be warned it’s designed to put the computer over your stem so it looks silly If you put it in ‘out front’ mode.
Doesn't look as good as it would over the stem but it works well.
[url= https://live.staticflickr.com/65535/48807983893_ddf4cbcf92_b.jp g" target="_blank">https://live.staticflickr.com/65535/48807983893_ddf4cbcf92_b.jp g"/> [/img][/url]
Ha! Mine is out front as well because I haven’t trimmed my steerer all the way down. I guess it just looks weird compared to the aero mount on a road bike.
Having my GPS offset like that would drive me nuts.
I went for a loop mount that puts the Wahoo over the stem.
K Edge was £45.
Superstars version is utterly rubbish as the Wahoo just spins and falls off (same as the HUP branded one)
Finally settled on this bargain which also holds the Wahoo firmly, and the hinge means you don't need a 10mm spacer to ensure it clears the stem clamp.
like the look of the loop mount one, i that off amazon? looks like one ive seen on there, cheers.
