Virgin bleeder
[Closed] Virgin bleeder
[#368710]
I'm gonna bleed/fill some brakes with oil for the first time (shimano saint) In the shimano instructions there are two different methods I'm going to try the first one, any special tips?
I was thinking of removing the brake from the bike so the caliper was hanging below the lever, would this help? Also that little "H" shaped thing in the reservoir body, does it need removing?
Posted : 06/03/2009 10:05 pm
You fail.
H in the reservoir? Leave it alone!
Try reading the shimano instructions!
Posted : 06/03/2009 10:25 pm
HAve you got the correct oil? Not car brake fluid for Shimano.
Posted : 06/03/2009 10:42 pm
I have read the instructions which say nothing about this where as a bike radar article states
"there’s a blanking plug under the cap to catch you out that needs removing."
How do you know to leave it alone?
thanks
Posted : 06/03/2009 10:44 pm
oh and I have proper shimano oil.
Posted : 06/03/2009 10:45 pm
I think the blanking plug they mention is probably the diaphragm under the cap, bled one in work yesterday and didn't notice anything abnormal to catch anyone out.
Posted : 06/03/2009 11:31 pm
So you left the little metal "H" in the photo in place? [url= http://www.bikeradar.com/gear/article/workshop-how-to-fit-shimano-disc-brakes-18265 ]here is the bike radar article[/url] think i might take down the shop 😕
Posted : 06/03/2009 11:42 pm
I've always found bleeding brakes to be a pain, including Shimano brakes. I currently have 2 sets of XT and recently had to bleed them both. From the top down or bottom up, sometimes it works first time, sometimes it takes a few attempts. Although not strictly necessary, taking the caliper off and bleeding a straight hose (not kinked at the top obviously) is what I did on a second attempt on two brakes, but they still seemed a bit of a lottery whether it worked easily 1st time or not. Good Luck.
Posted : 06/03/2009 11:50 pm
Ok, my hand's up, I was caught out.The blanking plug they talk about is in the bottle, not on the lever.(Should have read the article.):)
Posted : 07/03/2009 9:27 am
MWAH!! :mrgreen: 💡
Posted : 07/03/2009 11:31 am
