views on using 2.35...
[Closed] views on using 2.35 Nevegals on 717s?
[#3601438]
Been meaning to try these out - will they be too big for a narrowish 717?
cheers
Posted : 24/01/2012 12:55 am
I've done it. Worked ok and never came off or seemed to squirm about - and I run 30psi or less. You're probably not giving them their full potential though. Those 2.35s are MASSIVE, I decided they were just too heavy and draggy, so switched to 2.1s...but I am a bit of a lightweight mincer.
Posted : 24/01/2012 1:00 am
Exactly as LenHankie, ran ok for me but draggy. 2.1's loads better.
Posted : 24/01/2012 1:18 am
LenHankie - Member
2.35 inches across, controversially 😉
I got on fine with mine on my 717s- the Mavic website says 2.1 only IIRC but the rim said 2.3. They didn't feel like they were excessively pinched, I now use them on 22mm rims and there's only a minor difference in shape.
Maybe a bit of a mismatch with 717s mind, but they're not delicate rims. The stick-e is pretty damn draggy, and can clog badly in sticky mud too (and the DTC is a poor front tyre, it's "pingy" if that makes any sense, likes to bounce off things). The 2.1 is an excellent, less draggy trail tyre.
I really like 'em but not for everyone.
Posted : 24/01/2012 1:19 am
I run this set up, works fine and as mentioned above not too pinched at all.
Not found them unduly draggy either, using the DTC flavour. Nevs are great tyres,
APF
Posted : 24/01/2012 3:31 am
