Fitted some new Uber pads couple of weeks back. Tonight the rear brake is vibrating through the frame like mad, noisy and annoying, but still working fine.
Is it the calliper has come out of alignment, loose bolts or shit pads ?
Ta
Posted : 08/05/2017 9:00 pm
I would re-align the caliper and clean the disc with IPA to rule out both sub-optimal pad contact and a contaminated rotor.
Might also want to carefully re-set the pistons after giving them a bit of a clean and lube too.
Posted : 08/05/2017 9:04 pm
Last time this happened to me the rotor was worn unevenly.
Posted : 09/05/2017 9:05 am
