Just gone up to a 180 from 160 rotor on the front, and now under braking the fork judders. Anything I can do to stop this?
Posted : 28/07/2010 7:31 pm
Brake less
Posted : 28/07/2010 7:47 pm
Check everything at the caliper/rotor is tight, check the pads, check the rotor is straight, make sure you have the right adaptor, check forks for play and check headset.
Posted : 28/07/2010 8:06 pm
? contaminated pads or rotor?
Posted : 28/07/2010 8:07 pm
Check everything to do with the caliper is sqaure and aligned correctly, then just ride for a little bit, it may be the disc needs to bed in to the pads and vice versa.
Posted : 28/07/2010 9:10 pm
also not unknown for it to be caused by wavey or non-concentric braking surfaces, or pads overlapping the braking surface and catching on the rotor's spokes.
Posted : 28/07/2010 9:27 pm
