Vertical bolt-on Ga...
[Closed] Vertical bolt-on Garmin mount
[#7196010]
As above; after a more secure clamp (that won't shake loose on cobbles) that bolts to a 31.8mm bar; happy with Garmin sat over bar rather than out in front. K-edge etx don't seem to do these; anyone have any suggestions?
Thanks,
Andy
Posted : 15/07/2015 8:48 am
there are some stem cap ones that look neat - if thats where you look
Posted : 15/07/2015 8:51 am
K-Edge do a top cap version but I bought the PMB version after a faulty K-Edge go pro mount nearly fudged my go pro case before K-Edge basically told me I'm a tosser and to shove it.
Nothing I didn't already know and I don't hold a grudge 😳
Posted : 15/07/2015 9:16 am
barfly 3.0 sits over the stem, so does the cheap SRAM one if you rotate it, Raceware do a stem cap one with a bit of length so its not right over the stem cap
Posted : 15/07/2015 9:19 am
Have got a K-Edge top cap mount (which works fine, but looks a bit silly with 2 spacers between it and the stem). Now, how do I go about shortening my steerer....
Posted : 18/07/2015 6:33 pm
I use the Sram mtb one.
Posted : 18/07/2015 6:38 pm
