Just decided to hang all of our bikes using these [url= http://postimg.org/image/k0tftoh4x/ ]Link[/url]
They work just fine but I had a mild panic that the weight of the bike bearing down on the hook might dent the rim!! This is nonsense right and I'm just being daft?
are they made of cheese?
donks - MemberThis is nonsense right
Right.
donks - Member...and I'm just being daft?
Correct..... 😆
The rims aren't an issue.
Squidgy brakes from any trapped air moving around (ahem, Avid) and forks leaking their oil would be the things to worry about.
But, I'm sure it'll be fine 😉
Being daft, your bike is under far more strain while being ridden than hung up.
Cheers then..... Panic over
i use the generic wall hook for my bike. rest the back wheel on the ground and then used to hook the wheel but to save space i take the front wheel off and attach the bike to the hook using the fork axle
