Velocity Blunt or F...
[Closed] Velocity Blunt or Flow EX or Other
[#6969810]
A recent haze of indecision has lead me to need to ask this - like a whet tyre thread but even less interesting ..... 😡
I have a Rohloff hub that I keep meaning to get built up for use on a couple of bikes.
The plan was originally to swap out my Fortitude for a Longitude and have the Rohloff built into a Dually to match the front.
This isn't looking like a reality at the moment due to ££, the Fortitude being a lovely ride and the fact that the Rohloff set up on the Longitude looks to be a right PITA.
Sooo
The clearance on the back of my Fortitude isn't great and I currently run a 2.1 Prowler on a Flow (non EX) rim laced into an Alfine.
The other bike is my Skookum that should take a slightly wider tyre.
I would like to only need to build the Rohlfoff once and the reality of having a frame capable of taking a 29er+ in the rear anytime soon isn't likely 🙁
The Flow EX seems a sensible option but the Blunt is a touch wider. Both can run tubeless (although I run tubes 😳 ), both are about the same price but importantly both [i]could[/i] run a 3'' tyre although granted not optimally.
So with you money what would you go with?
Posted : 31/03/2015 4:24 pm
I have 26" blunts on one bike - they do change the shape of the tyres you run so some care is needed to make sure you dont' end up with a great mass of sidewall with a little tread on top. I've not run anything smaller than a 2.2" Rubber Queen on mine so not sure how they'd be with narrower tyres.
Posted : 31/03/2015 4:32 pm
I would have recommended the Superstar DS25 rim - I've got a pair and they're ace.
But I read on their FB that there's a new wider version in the pipeline - so maybe wait for that?
Posted : 31/03/2015 6:17 pm
