Velcro to reduce bi...
[Closed] Velcro to reduce bike noise - Does it work?
 Rik
[#340574]
Just got a new Orange Five and it is a great, great bike so far, it makes a racket coming downhill. Although i've had full sus bikes before, i've never had one this noisy DH.
I understand that box construction amplifies the noise. I have read in DIRT that the pros use the fluffy side of velcro to reduce the noise.
Anybody tried it, does is actually work and will it make a difference on a Five??
Posted : 25/02/2009 7:02 pm
Sam Hill uses it in parts, especially to stop chain noise. I was recommended to fill the hollow monoque sections with expanding foam to deaden the noises.
Posted : 25/02/2009 7:03 pm
yes, I could probably grab you a strip from work if we have any?
Posted : 25/02/2009 7:06 pm
Oranges are renound for being very noisy. If you have the cables running through the swingarm that makes them loud. Also look at reducing chain slap and noisy mechs.
Posted : 25/02/2009 7:08 pm
Seems to be working for me. I did it my newly built coiler and it was much quieter than I was expecting.
Posted : 25/02/2009 7:09 pm
 Rik
Cool if it does work
How easy is it to clean Mr.N?
I've got a white Five so was thinking about white velcro which i've seen you can buy. But no good if if stayed brown after a hose down, or stained a funny yellow colour.
Posted : 25/02/2009 7:11 pm
In my experience it didn't work. Tried it on my 5, it wouldn't stick because the underside edge of the swingarm has a weld running long it making too much of an uneven surface for it to stick too.
Weirdly, i find my 5 ALOT quieter than the Marin Wolf Ridge it replaced! I run a 36/24 chainset to perhaps the reduced chain length contributes to less noise??
I do have a strip of frame protector film which might help also. Running a shadow mech may help also as it only has the one pivot so doesn't swing around too much.
Posted : 25/02/2009 9:06 pm
the stuff we use is industrial tackle so its gonna stick, I would imagine that it would clean up ok unless you let it dry?
Posted : 25/02/2009 9:11 pm
Yep, works a treat on my Jekyll.
Posted : 25/02/2009 10:10 pm
Works for me too.
Posted : 25/02/2009 10:51 pm
Fantastic stuff, buy the heavy duty stuff and it will stick to anything. I also use it to prevent cable rub, strangly although a cable will go through your paint and into the metal in a couple of rides velcro seems impervious.
Posted : 25/02/2009 10:55 pm
I use it on my Tazer chainstay. It is a very noisy bike - every little knock, creak or whatever is amplified tenfold but having said that at least I don't get any chain slap 😉 and the iPod helps . . . a lot. Reckon the expanding foam would've been a good idea though.
Posted : 25/02/2009 11:02 pm
