Value 1x11 upgrade?
[Closed] Value 1x11 upgrade?
[#7798868]
I'm looking at upgrading the 1x9 setup on the n+1 hardtail, and considering getting some 11 speed action as its trickled down the price categories now. I've already got a Hope 32t chainring on the front which I assume will still be suitable, so just need mech, shifter, cassette, and chain I guess?
Who has the best deals atm? I'm all Shimano, but might be pursuaded to give SRAM GX a go.
Posted : 29/04/2016 2:55 pm
Yeah that's roughly what I paid but I picked the cheapest bits from Evans / CRC so I could get the shifter than mounted to my brakes.
Failing that 11sp SLX won't be long, but because it's new it might be one of those odd situations when M7000 Slx is more expensive than M8000 XT because M8050 pushes the price of M8000 down, or something, so many numbers...
Posted : 29/04/2016 3:07 pm
looks decent SR, how come it's "preorder"?
Posted : 29/04/2016 3:13 pm
Shimano xt probably about the cheapest way of doing it atm, just shy of £150 should sort you but use a sram chain. Benefit of new xt is you can get it in ispec b flavour if that suits your brakes.
Posted : 29/04/2016 4:38 pm
I've just calculated Sram NX at £139.15
XT bought separately with a SRAM chain is £152.10
Neither include chainring.
All from UK shops (CRC/Merlin/Tredz I think)
Posted : 29/04/2016 4:51 pm
You've also got a gripshift option with Sram (same price) should that float your boat (I haven't tried it since the early nineties)
Posted : 29/04/2016 5:02 pm
Cheers guys, NX is interesting, but I'll have to check the respective weights if there's only a few quid in it with XT and GX.
Posted : 29/04/2016 8:38 pm
Make sure that your rear hub is compatible with 11 speed casette...
Posted : 29/04/2016 9:33 pm
For NX and XT it all fits on a 9/10 speed compatible hub.
Why use a SRAM chain, the ultegra / XT one is superb
Posted : 29/04/2016 9:45 pm
I did'nt think that xt 11 speed cassette would fit on a 9/10 speed hub?
Posted : 29/04/2016 11:12 pm
[quote=Andy_K ]looks decent SR, how come it's "preorder"?I'm assuming they're just getting a few in as and when ordered.
[quote=thorpedo ]I did'nt think that xt 11 speed cassette would fit on a 9/10 speed hub?It does
Posted : 29/04/2016 11:13 pm
Beware the NX cassette, the XT one is already heavy (430g) but the NX one is 540g! Also the NX is more likely to cause cassette bite.
I've been running XT 11s for six months now and frankly not been that impressed. I was on 1x10 before with a 11-42 range and than seemed fine for me. I've got a GX cassette on order so maybe 10-42 is 'worth' 11 speeds but were I to do it again I think 1x10 with a dedicated 11-42 10 speed cassette (i.e. Sunrace) would be better. Then you can pick up on Shadow+ kit down to Deore level (got this on my son's bike and it all works great).
Posted : 30/04/2016 8:17 am
All the 11sp cassettes that have a 11t smallest cog fit a standard freehub body thorpedo.
SRAM chain is my personal preference, but nothing wrong with XT as long as you use a compatible quick link. Shimano are launching their own soon.
I hadn't realised the NX cassette was that heavy. Quite off putting. The lighter cassette is about £30 more expensive which pushes me back towards XT for my son's bike
Posted : 30/04/2016 10:30 am
AlexS, in the NX's favour, it's all steel, so less wear (except on the freehub), but those is alotta grams... Check out the Sunraces though; their 'X' versions have an alu 42T and the 'S' in steel. The 10 speed 11-42, all in steel, is 450g and about £35... *edit* the Sunrace spiders are alu, even on the S model, so kinder on the freehub. Sunrace X model 11 speed 11-42, 401g.
Posted : 30/04/2016 11:27 am
http://www.tritoncycles.co.uk/components-c9/cassettes-freewheels-c68/sunrace-ms3-10-speed-cassette-p14798, bargain, same range, weight and smoother (IMO) and cheaper than 11 speed.
Posted : 30/04/2016 11:37 am
Sunrace making a come back, hoodathunkit?
Posted : 30/04/2016 12:16 pm
Microshift also do an 11-speed package for a very reasonable price but they don't seem to be on sale in the UK
http://www.bikerumor.com/2015/03/21/tpe15-microshift-gears-up-w-mega-40-wide-range-mountain-bike-cassette-derailleur-system/
Posted : 30/04/2016 12:29 pm
I've just got an xt chain,derailleur,11-42 cassette an shifter from Taiwan for £140... So 150 in uk prices seem pretty good...
The sunrace stuff looks well interesting seems a cheap way to get an expanded casette...
DoD
Posted : 30/04/2016 12:35 pm
I'm still on ten speed XT with a Sunrace 11-42 cassette and I can't fault it.
The only reason I have to upgrade is cog-snobbery of a Spinal Tap-esque nature. I'm really pleased to see that Sunrace produce an eleven speed alternative cassette to XT.
Posted : 30/04/2016 12:42 pm
Using SRAM 11x1 Rival and don't miss the front mech at all.
Just might need to think your chainring (using a 44T here combined with a large range cassette).
Sone riders love it and some hate it.
Marmite.
Posted : 30/04/2016 12:46 pm
steve_b77 - Member
Because Sram chains come with a quick link, while shimano persist with an annoying pin. Reason enough for me.
Posted : 30/04/2016 1:42 pm
