V brake travel adju...
[Closed] V brake travel adjuster setup
[#3336718]
Hi anyone got a picture of their setup please? Think I have it right but would like to make sure.
Set mine up and worked fine but had to remove cable to put some rubber washers on the cable to stop it rubbing. When I removed the cable from the pulley the hole the cable is thread through opened up / snapped. Anyone else had this problem when changing cables?
Posted : 10/11/2011 1:26 am
Bump
Posted : 10/11/2011 11:08 am
Which travel adjuster is it that you have?
Posted : 10/11/2011 12:27 pm
Xtreme one with barrel adjuster.
Posted : 10/11/2011 1:51 pm
I've got pics but not sure they'll be clear enough
If you've got a pic of yours it'd be easy enough to say if you did them right. That said, the hole shouldn't really be under any load so even if it's opened up it shouldn't really be a major problem though of course it is on a safety critical part...
Posted : 10/11/2011 1:55 pm
Here is a picture:
Gone around the small pulley through the hole onto the big pulley around this and out.
[url= http://farm7.static.flickr.com/6216/6332566183_bdcca19d2c_m.jp g" target="_blank">http://farm7.static.flickr.com/6216/6332566183_bdcca19d2c_m.jp g"/> [/img][/url]
[url= [/url] by [url= http://www.flickr.com/people/beargotsoul/ ]bear406z[/url]
[img][url= http://www.flickr.com/people/beargotsoul/ ]bear406z[/url][/img]
Posted : 11/11/2011 3:43 pm
Think I need to move the pulley so that the hole into the large pully is at the top?
Posted : 14/11/2011 1:06 pm
Bump
Posted : 15/11/2011 1:41 pm
Yeap, like Clubbers
cable should go half way round the small pulley out the hole at about 12 o'clock and follow round the big pulley before exiting
Posted : 15/11/2011 1:45 pm
Thankyou cyclistm and clubber
Posted : 15/11/2011 2:34 pm
