v brake post studs
[Closed] v brake post studs
[#268440]
i have a commencal absolut crmo frame and i want to run v brake in the rear. it has 3 bolts on both sides of the upper chainstay presumably to fit a brake post to. im having trouble finding a brake post to fit in the hole though. the only brake posts i can find are for sus forks and the thread is to big to fit in hol in the frame.
is it usually a smaller thread for rear brake post studs or have i got a **** of a frame?
does anyone know where i can get one?
thanks in advance
Posted : 02/02/2009 8:56 pm
ha it stars out the word ****.... clever
Posted : 02/02/2009 8:57 pm
Forks and frames can be different sizes. Usually forks are M8 and frames M10
Posted : 02/02/2009 9:10 pm
ah so does the m10 fit in a smaller hole. it sounds like thats what i need. my lbs isnt so local so dont really want a wasted journey but are they a common thing? cheers seamus
Posted : 02/02/2009 9:20 pm
No, it should be the other way round M10 is bigger than M8. Difficult to be more specific without seeing the problem. Are you sure the holes are for the pivots?
Posted : 02/02/2009 10:01 pm
i cant think what else they could be. the frame is advertised as detachable v brake posts to so im 99.9% sure. the bolt that fits in the hole has about a 4mm diameter thread... if that helps. im gonna try contacting commencal about it also and see if they can tell me exactly what i need.
Posted : 03/02/2009 11:41 am
beware there are 2 different 'pitches' of thread too: the v brake studs on my maxmax have a different pitch to the ones on my maxlight. (maxmax ones have fewer, wider threads)
Posted : 03/02/2009 1:13 pm
ha would do they dont like making shit simple!
Posted : 05/02/2009 11:49 am
