V-brake Levers for ...
[Closed] V-brake Levers for 4 Year Old
[#7328615]
I'm looking for a set of v-brake levers for my daughters Ridgeback Honey. It's a 14" wheel bike with V's. I cannot find anything suitable. I ordered the Tektro junior ones. They turned out to be the same size as my own brake levers!
I tried Islabike but they only supply to fit their own bikes.
Anyone found a supplier yet? Many thanks,
Posted : 14/09/2015 12:41 pm
I have an Islabike in the shed that the neighbour reversed over - the brake levers were at the salvageable end IIRC, I can check late, and sell them to you if you're interested.
Posted : 14/09/2015 12:59 pm
I have some Avid SD1's in the shed - they wind in nicely.
The Tektro one's usually can be wound in a long way as well - I have a couple of pairs as well.
You would be welcome to them for postage..
Posted : 14/09/2015 1:08 pm
My daughter had the same problem with the ridgeback honey.I solved it by buying an islabike cnoc. Sorry this is no help whatsoever
Posted : 14/09/2015 1:11 pm
honourablegeorge - You got mail.
Posted : 14/09/2015 1:21 pm
Add a back peddle back instead......I've always hated them as a kid...but when my son was 4 I got him the specialised 16" hotrocks bike and they come as standard on them ....and it makes sense with his then ..little fingers
Posted : 14/09/2015 1:50 pm
I've used an XT lever on the balance bike I made for my daughter. To alter the lever reach I made a sleeve that fitted inside the lever to reduce the reach. Works very well.
Will see if I can get a pic later if you're interested?
Posted : 14/09/2015 1:53 pm
I thought the islabike ones were rebadged tektro. I'll take a look in a bit
Posted : 14/09/2015 2:06 pm
If none of the above options work try Frog bikes. Very lovely and helpful at Frog.
Or couldn't you just say to Islabike that you need to replace the v-brakes on an Islabike? (I know lying is [i]bad[/i] 🙁 )
Posted : 14/09/2015 2:12 pm
It was a Tektro one on our Islabike Rothan.
Posted : 14/09/2015 2:16 pm
So the cnoc had a tektro TL67
Posted : 14/09/2015 3:50 pm
Pretty sure it is Tektro JL350 you need btw
**edit sorry cross posted. The ones I got from Frog are Tektro JL350 and are perfect
Posted : 14/09/2015 3:56 pm
Tektro ts 325 wound all the way in work for our 4 yr old as a replacement on a cnoc 14. The cnoc has an undersized handlebar and I've had to use a bit of inner tube to bulk it out a bit.
Posted : 14/09/2015 4:12 pm
Google reveals nothing for the tl67 but googling jl350 pics suggest they are the same as the ones on the Isla bike.
I think you'll need some tektro mini vs too as the brakes on the ridgeback aren't great either.
Posted : 14/09/2015 4:45 pm
After some more googling it would appear that Islabikes have a 19mm handlebar. Which means the Islabikes/Tektro JL350 levers won't fit a Ridgeback as it has standard 22.2mm bars. It's looking like my daughter might have to make do with carp brakes until I can afford an Islabike.
Still, I'm guessing all of us learnt to ride on bikes with next to no braking - and we all seem to have survived!
Posted : 14/09/2015 9:52 pm
I fitted Avid Speed Dial 7 levers to my daughter's bike. Loads of adjustability and way better than the 'so called' Tektro kids levers.
They're £14.99 from CRC.
I've got to say that the levers on my daughter's Cnoc were perfect for small hands. Shame they only fit a 3/4" (19mm) bar.
Posted : 14/09/2015 10:12 pm
I have a set of Tektro JL352 levers. Same levers as the JL350 levers mentioned above but to fit 22.2mm bar diameters.
Email in profile if your interested.
Posted : 14/09/2015 10:23 pm
woodlikesbeer - Member
Hi... just replied to your email, yeah, bars are 19mm - so the levers probably no use to you, sorry.
Posted : 14/09/2015 10:26 pm
We have the JL350 on 22.2 if that helps
Posted : 15/09/2015 7:25 am
peabrain - when you say we do you mean you work for someone who sells them? Can you send me a link please. Email in profile.
Many thanks
Posted : 16/09/2015 12:22 pm
Sorry, just meant that my son's bike has the JL350 levers on 22.2 bars. We got them from Frog bikes.
Posted : 16/09/2015 4:00 pm
I think I just found an alternative....
[url= http://www.raleigh.co.uk/ProductType/ProductRange/Product/Default.aspx?pc=2&pt=55&pg=1101 ]Raleigh Junior Brake Levers[/url]
They say they are for both v and canti brakes. I'm guessing they have a pull ratio of somewhere between the two. I'll order a pair and see how they work. I figured worse case scenario I can just add a set of mini-v's. As mini v-brakes are aimed at road bike bikes that should over come any pull ratio issues.
Posted : 16/09/2015 9:03 pm
I just found these while looking for something else, and thought of this thread - they look like exactly what you need, rather than the non v type you mention above:
http://www.jejamescycles.co.uk/raleigh-junior-v-lever-20-24in-id62786.html
On another note, I was looking for a replacement tyre for the Cnoc 14 I just got second hand for my son. It's a 14 inch Kenda, but I can't find a direct replacement. Anyone got any suggestions of somewhere that carries them?
Posted : 02/10/2015 1:39 pm
The best place I've found to hunt for 14" tyres has been eBay to be honest...
[url= http://www.ebay.co.uk/sch/Cycling-/7294/i.html?_from=R40&_sac=1&_nkw=14%22+tyre ]http://www.ebay.co.uk/sch/Cycling-/7294/i.html?_from=R40&_sac=1&_nkw=14%22+tyre[/url]
Posted : 02/10/2015 2:17 pm
Ta, I'll take a look - ideally I want some small block 8s to replace what's already on it - can't have mismatched tyres for his pride and joy!
Posted : 02/10/2015 5:09 pm
I'll just leave this here...
http://www.btwin.com/blog/blog-and-news/sports/kids/revolutionary-brakes-for-childrens-bikes/
Posted : 02/10/2015 5:22 pm
Those stop easy brakes look great
Posted : 03/10/2015 1:18 pm
Did anyone find a uk source for the jl350? My google skills are failing
Ta
Posted : 03/10/2015 8:15 pm
Did you get in touch with frog bikes?
Posted : 03/10/2015 8:54 pm
Single track bikes in Scotland have a load of 14" tyres in, got a set of nutrak bmx ones for my lads frog 43 and they're ace.
Posted : 04/10/2015 7:17 am
