Pie Roller UST got teeny hole just above the bead, pinprick size. Will only seal temporarily when sloshing the stans about. Puncture kit feather patch, park glueless less patch, superglue- que?
stick one of the weldtite slugs through it and loads of vulcanizing solution. I have done this on 3-4 tyres and its fine. The nay sayers who reckon it won't work are wrong
tubeless repair kit like what rofl said, just trim it carefully if it's near the bead
Have used the weldtite patches and also std rema ones if the inner rubber will take it.
Small tears on or near the bead are a bugger to patch - superglue applied liberally inside and out and worked well into the tear does the job for me (Bonty TR tyres, though so not "proper" UST).
Usually results in fingers stuck together too.
