Using shimano 10 sp...
[Closed] Using shimano 10 speed mechanical disc brifters with caliper road brakes
[#11880104]
Does this work? I doubt it - suspect cable pull is wrong - but does anyone know for sure?
Thanks
Posted : 13/05/2021 5:20 am
I don't think they are any different are they?? I've never heard of specific disc or rim brake shifters, just hydro or cable.
Posted : 13/05/2021 6:17 am
Should be OK as road discs are optimised for the shorter pull of road levers.
Posted : 13/05/2021 6:43 am
Assuming they are fairly modern calipers, yes, it should work. Older models used a bit less cable pull.
List here says what should be compatible. https://productinfo.shimano.com/#/com?acid=C-456&cid=C-453
Posted : 13/05/2021 7:15 am
