A friend told me you should not switch on pro pedal while on the move, although he was not confident about this.
I cant find reference to this in my manual. it's mentions lock out on the forks is OK on the fly but no mention of pro pedal.
Can you use it?
switch mine on and off on the fly, however, on the rp23 you cannot switch between the 3 pro pedal settings on the fly, the shock needs to be fully extended to do this and the pro pedal lever in the off position, also think you must change numerically ie 1-2, 2-3, 3-2, 2-1, can't go 1-3 or 3-1.
You can flick the lever on the fly, you shouldn't switch which propedal position (1, 2 or 3) while on the bike is what I've been told.
EDIT: beaten by 7 mins, that'll teahc me to open multiple threads and then reply to them without refreshing...
