Using Percil to was...
[Closed] Using Percil to wash Goretex:(
[#422410]
Has anyone done this? Will grangers fix it or is it boll0xed?
Posted : 25/03/2009 6:21 pm
usually ok if it's not got conditioner/fabric softener in it
Posted : 25/03/2009 6:24 pm
It's bolloxed.
Do a hot wash with nothing in the machine. This will get rid of any detergent traces.
Wash in Nikwax Techwash or the equivalent Grangers cleaner - this is to remove any detergent on the garment
Now wash again in Nikwax or Grangers re-proofer.
Tumble dry or iron to activate the finish.
Next time, use soap flakes.
Posted : 25/03/2009 6:31 pm
Didn't use conditioner, did it ages ago and it's not been right since- think I'll try grangers first and see how it goes
Posted : 25/03/2009 6:32 pm
Cheers Druid, I'll try that- don't really want to fork out for a new jacket but I'm getting sick of it leaking through all the time 🙁
Posted : 25/03/2009 6:36 pm
 aP
Do people really have tumble dryers at home? 😯
I guess that helps to explain some people's enormous electricity bills.
aP - Member
:mogn:
Posted : 25/03/2009 6:48 pm
You don't need a hot wash. 2 cold water rinse cycles is adequate.
You're trying to remove detergent residue from the machine. Volume of water does this and relative concentration of the solution - not temperature.
Probably best to rinse the machine and jacket together since both are conaminated. Since theres a greater detergent load in the jacket, Its rinse twice, then run a normal wash cycle with n detergent or soap of any description, hen re-proof using any mehod of your choice.
Posted : 25/03/2009 7:37 pm
I have a tumble drier. My leccy bill for the winter quarter was £70 for a 3 bed house 🙂 I bought the drier for reproofing jackets, and probably used it about once to dry cycling kit in a hurry.
The above btw is good advice but also take the detergent drawer out (most machines can do this unbeknownst to their owners) and clean the gunk off that too.
Posted : 25/03/2009 7:43 pm
You'll be fine Danny.
Do a machine cycle with nothing in it to remove the detergent, The put the coat in with some grangers pure soap.
When its done, then do the same again with grangers re-proofer. Then tumble dry.
Jobs a good un.
Posted : 25/03/2009 7:45 pm
Trip to merlin at lunchtime tomorrow then for the grangers-looking out the window think I'll need it this weekend lowey
Posted : 25/03/2009 7:49 pm
whats the 2 in 1 from grangers like
Posted : 25/03/2009 7:56 pm
I go gentle with soap suds and 30C if you can't find the proper cleaning materials.
Also you can buy those sprays to water proof jackets.
Don't use bleach or biological cleaners.
Thing is ask anyone at Tesco and they won't know. I ended up ringing Endura to make sure I didn't knacker their top end stuff.
Makes you think twice when buying gear!
Posted : 25/03/2009 7:59 pm
 sv
I found separate wash with soap flakes or a non-bio then reproof with the spray on-tumble dry method worked best for me.
Posted : 25/03/2009 8:32 pm
Obviously I usually wash Goretex (and similar) kit with soap flakes, rinse thoroughly, and reproof carefully... but I have also stuck a lot of water proofs straight through normal washes, with bio powders and not bothered reproof them for years. IME* it won't do them any long term damage - just rinse thoroughly (can't see any point in washing [i]again[/i] with soap flakes) and reproof (I usually use a wash-in type and tumble dry).
* caveat on abuse of fabrics mostly limited to older generations of Goretex, but have also abused (usually accidently) an array of the latest hi-tech wonder fabrics 😉
Posted : 25/03/2009 9:31 pm
