Using Fox 20wt flui...
[Closed] Using Fox 20wt fluid in a Pike instead of 0-30wt
[#12059271]
I presume it would be ok to use Fox 20wt gold fluid (which I have) in my 2016 Pike until I can get the 0-30wt stuff?
Or will it destroy something internally and lead to certain death?
Posted : 03/10/2021 7:33 pm
I've been using Putoline 10w motorbike fork oil in my forks for about 10 years. Not died yet!
Posted : 03/10/2021 7:49 pm
I used the same stuff in my 2021 Pikes and they’re mint!
Posted : 03/10/2021 7:52 pm
You'll be fine, there's barely any difference in viscosity, and the reality is the forks are similar internally, so the same across all forks in the lowers, it's not exactly a harsh environment for oils when they're added in a few mm into a fork lower.
Posted : 03/10/2021 8:08 pm
I'd say the Fox 20wt is way better than the Rockshox stuff. The only oil I like better is Supergliss 100.
Posted : 03/10/2021 8:28 pm
Thanks all. Is anyone using fork grease as well as oil or is that unnecessary really?
Posted : 03/10/2021 8:30 pm
I always use grease in the wiper seals and shafts, customers always say that the fork feels better than new
Posted : 03/10/2021 8:34 pm
given I've has a couple of RS forks arrive dry from new, that can't be to difficult. Always drop the lowers on new forks.
Posted : 03/10/2021 8:46 pm
@bruneep it's weird, sometimes no oil, sometimes a dribble in one leg 🤷🏻‍♂️
Posted : 03/10/2021 8:49 pm
Been using the Fox gold stuff on Lyriks for years, zero issues
Posted : 04/10/2021 8:51 am
Why not just order some Pike fluid and wait?
BikeTart have it in and stuff from them normally arrives within a couple of days.
Posted : 04/10/2021 9:10 am
Couple of reasons not to do that.
1. OP has Fox 20wt in stock.
2. Fox 20wt works better than the Rockshox stuff.
That's no just my opinion, there's a chap called Dougal at Shockcraft in NZ who has done some pretty extensive testing of this. That's where the recommendation for Supergliss comes from.
Posted : 04/10/2021 9:17 am
It probably all comes out of the same place anyway.
Posted : 04/10/2021 9:58 am
Think I use 15wt in all my forks now, on J-Tech's advice.
Couldn't say if it was better but it's certainly not any worse.
Posted : 04/10/2021 10:06 am
Yep. I've always imagined they just buy drums of generic damper fluid and hire a student to stick it in bottles and put stickers on it, then mark it up by 1000%. They probably sit round laughing their arses off reading online forums like this.
Posted : 04/10/2021 10:11 am
For the lower legs? the fluid is just for lubricant rather than damping so dont see why something else wouldnt work!?
Posted : 04/10/2021 1:32 pm
For the lowers I've got a litre o 15W Motul Fork oil, I'll be using that until runs out in approx 2036.
I'd use the specified fluid for the damper though
Posted : 04/10/2021 1:41 pm
