Using 160mm forks o...
[Closed] Using 160mm forks on Turner 6 pack
[#3437412]
Hi there, has anyone got any experience of using 160mm forks on a 6 pack, does the geometry work out ok?
Also any recommendations for 160 forks?
Posted : 07/12/2011 9:38 pm
I'd head over to the very active mtbr Turner forum; they are a very helpful bunch.
Posted : 07/12/2011 9:58 pm
I've got a Turner RFX, ( a 6 pack in all but name ) on which I used to run 160mm travel Fox Floats, & it was fine. Used to use it for general xc riding, but weighing in at 34lb it was a tad heavy.
It's now fitted with 180mm Marzocchi 66's, but now only gets used for alpine trips & uplift days.
Posted : 07/12/2011 10:06 pm
160mm Fox 36 Vans on my SixPack, no problems. Bottom bracket can start getting a little high - especially if you're using big tyres, but it can be lowered slightly and angles slackened by about 1 degree with offset shock hardware, alternativly a 5spot seat stay - if you can find one - will give similar results (its shorter than the 6pack one) to the bushes, but with less tyre clearance at the top yoke.
Posted : 07/12/2011 11:21 pm
I believe the OP has actually got a 5-spot rear triangle, so it's actually a 5-pack. So looks like it'll have a lower BB height.
Coil Lyrics FTW, although dyer - you'll need to Extra Light spring, as you're a waify weed.
Posted : 08/12/2011 7:23 pm
Been running fox 36 vans on a six pack for about five years now. Great all day bike around the peaks.
Posted : 08/12/2011 7:41 pm
