Up in scotland for weekend and my freehub is slipping. How do they come off. Cassette off, full through axle without internal threads/flats, no circlip, but won't pull off. Help. Grrrrr
if it's an xc 300 from the non drive side with a very long 11mm allen key
usually have to bash it [the axel] out with the bearing coming with it then get an 11mm hex in a vice and use the wheel turning it Counter clockwise IIRC.
I thought it was a 12mm Tazzy. Have you been drinking the green stuff again 😉
[url= http://singletrackworld.com/forum/topic/fsa-xc-300-sl-freehub-service-strip-down ]FSA Stripdown & Freehub Removal[/url]
Good luck boxelder 🙂
12mm fo sho
non servicable item anyhoo so roger irrelevant
flush many times with warmed oil if you are desperate dan
if you are not desperate dan wait for a new one £30!
I'll have to check mine, could av sworn twas an 11 although that may have been some old 'dale hubs. My mind is going
Thanks folks. Sprayed a load of GT85 in and worked intermiiently for 3 hrs, then failed totally - freewheel/scoot down to Feshibridge. 90km on saturday though, so not too short-changed.
No need a freehub and soke key (the Fly Spline Drive jobbie) if anyone has eaither going spare.
