ok so bought a park chain splitter and need to split the chain on a bike in the shed.my worry is the bike is a cheapo jap mtb and the links on the chain,well the pins look like they are sort of domed over? the links on my full sus which has a shimano hg73, the links on that are sort of flush and i would expect they will push out no problem.
so can i push the domed head ones out?there is no power link so how are these jointed/split???
Give it a go, WCS is you need a new chain.
Why are you splitting it?
Just push the pin out far enough to break the chain, then you should be able to reverse the tool round and push the pin back in again...
<<Just push the pin out far enough to break the chain, then you should be able to reverse the tool round and push the pin back in again... >>
though this does nto work on sram chains
<<Just push the pin out far enough to break the chain, then you should be able to reverse the tool round and push the pin back in again... >>though this does not work on sram chains
I've always done it on Shimano, Sram etc. chains without a problem
(surely too late, but ...)
buy a powerlink & remove 1pr of outer plates from your chain - costs a couple of quid & makes cleaning/changing much easier
oxym0r0n - Member<<Just push the pin out far enough to break the chain, then you should be able to reverse the tool round and push the pin back in again... >>
yer works fine on shimano chains(using their special pin), but really should not rejoin sram 9 speeds by putting the std pins back in - but if it has worked for you good luck to you.
No "Shimano special pin" just the standard one & the standard SRAM one, KMC etc. Why should I not really be re-joining these chains? So Shimano can charge me £2 for a special one? Have not had a chain breakage for 10yrs - racing "4hr, 12hr XC etc.
I must be just lucky 😀
<<I must be just lucky >>
you must be 😉
