Upsweep, Back sweep...
[Closed] Upsweep, Back sweep, 780mm, BUT Zero rise?
[#7953651]
first off, i'm just being obsessive, but does anyone know of a bar like this? let's say 9 deg up, 5 deg back, or similar usual numbers, but no actual rise section?
i do have one at the mo, a gravity gap, with 10 up, 4 back and zero rise, but it's 740mm and i'm feeling the need for something longer.
a small say 10 or 12mm rise is alright, superstar oens like this on another bike ok, but they're out of stock and i'm still searching for the grail...
Posted : 19/07/2016 3:55 pm
Time for me to be stupid:
How, if it has an up sweep, can it have zero rise? unless it has a raised clamp section then curves down before sweeping back up in a vaguely W shaped arrangement?
Posted : 19/07/2016 3:59 pm
Up sweep is the angle over the length of the bar (from centre to end) which I think is to position the bar in a comfortable place for your hands. Rise is a pronounced step either side of the clamp area designed to lift the bar above its clamping height.
Posted : 19/07/2016 4:05 pm
thanks nixie.
don't see any upsweep on that atlas bar benpinnick?
possibly a bit overkill for me too, but worht a look thanks
Posted : 19/07/2016 4:10 pm
 momo
10mm rise Nukeproof warhead, near enough look flat. A little longer than you've requested at 800mm though easily cut down. I picked mine up for £30 from a shop on eBay.
Posted : 19/07/2016 4:13 pm
 LAT
Spank do 5mm rise bars that are flat with an offset bulge. Not sure how wide they go.
Posted : 19/07/2016 4:15 pm
Crank Bros Cobalt 11- 8mm rise, and I think 9 degrees up and back. Very very soft though, I wouldn't put them on a hard-use bike (but they really take the sting out of a rigid...)
Renthal do a flat 780mm with 5 up and 7 back.
Posted : 19/07/2016 4:19 pm
On a flat bar you get the upsweep by rotating the bar forward in the stem, this does lessen the backsweep a bit though.
What Jabbi said. If theres no rise then there's no real point at which to measure up/backsweep against (other than an arbitrary mark on the bar), so its just a 'bend'. How much upsweep vs back you get is a factor of the rotation.
Posted : 19/07/2016 5:54 pm
sure, but i like the combination between the 9 and the 5, or whatever it is. whether that adds up to a combined sweep which i could achieve with say a simple 14 deg bend and the right rotation, i'm not sure.
i think there are still 2 'bends' going on and it doesn't amount to the same thing, but might be near enough for me.
i'm not going to buy lots of different bars to find out though...
Posted : 19/07/2016 6:22 pm
 PJay
I've got a 5mm rise (near enough flat) Spank Oozy bar (cut down to under 700mm) and it's a really nice bar; the Oozy bars are available at 760mm. There are various other models upto 800mm (although not all are available in 5mm rise versions); all appear to be [url= http://www.chainreactioncycles.com/spank/handlebars ]reduced at CRC![/url].
Posted : 19/07/2016 6:40 pm
They do a 780mm version of your current bar.... Well 777mm technically.
Gravity Light 777 aluminium or FSA Gravity Light which are aluminium with a carbon wrap. I actually have a spare unused pair of the carbon wrapped ones I'd be willing to part with, £30 posted?
Posted : 19/07/2016 7:32 pm
Syntace do a flat bar with 12deg sweep. You could rotate that upwards to get something close. Not sure if they are 780 though ... 760 seems to spring to mind.
Posted : 19/07/2016 7:37 pm
I have a FSA Gravity Lite and I love it.
Posted : 19/07/2016 8:55 pm
shit so they do!
i looked on their site the other day and couldn't see one.
thanks doug
Posted : 19/07/2016 9:52 pm
i too love my gravity lite. alu wrapped in carbon.
the gravity flat 777mmis ally only. shame. but looks loke it'll do otherwise.
Posted : 19/07/2016 10:23 pm
As above, got a spare pair of 777mm carbon wrapped ones if you're interested.
Posted : 20/07/2016 7:24 pm
