Do it through a laptop with my garmin
Possible to upload to iPad, kindle or hudl?
If they have bluetooth and the Garmin is a new one with bluetooth you can use the Garmin Connect app, at least on Android. Not sure about iThings.
Otherwise, not sure. If they can be connected via USB so they can see the Garmin's storage then you can upload the .fit file, but not sure if they can.
You mean straight to the movile device to cut out the laptop bit?
Some of the newer Garmins do this using bluetooth, what model do you have?
Edit:beaten to it.
Do any of them support an OTG cable?
Managed it before to android with an OTG cable...was a bit of a faff though, can't remember exactly how and I lost an activity along the way.
Worth looking into if your attention span is a little better than mine..,
Think I did it by connecting via otg cable, copying the data file across, then uploading it from there.
I use a USB connector with my 800 and 500 before that using an app called [url= http://www.sportablet.com/the-app.html ]Sport Tablet[/url] DC Rainmaker did a useful [url= http://www.dcrainmaker.com/2013/06/garmin-ipad-android-surface.html ]article[/url] on the subject. The 800 is a more complex due to file locations but simple enough given a few minutes and the FAQ on its website
Only have the edge 200
