Upgrade 120mm to 14...
[Closed] Upgrade 120mm to 140mm???
[#4028373]
Hi,
After some advice please. I have a Whytebikes 901 hardtail with 120mm RS Reba Team forks, as they are lower end of the range and two years old I am thinking about uprgrading them. But I am wondering if I could take the opportunity to swap them out for 140mm. My question is, would this have a detrimental effect on the geometry of the bike and would I get much benefit out of the additional 20mm of travel?
Cheers.
Posted : 01/06/2012 10:23 am
120mm forks setup correctly will be more beneficial than an extra +20mm.
Posted : 01/06/2012 10:25 am
Xiphon, that was my initial thoughts. Do you think it is worthwhile upgrading my existing forks or get them serviced...I'm confident I have them set up correctly for my weight etc but I' m thinking upgraded forks could be more supple and responsive.
Thanks for your reply by the way.
Posted : 01/06/2012 10:30 am
IMHO... the bottom bracket is already too high on the Whyte hardtails so adding a longer fork will make this worse. As Xiphon says, a better 120mm fork (or even a 100mm fork!) could(?) improve the handling (IMHO, YMMV etc etc).
RS Reba Team forks are not a bad fork by any means... what do you dislike about them?
Posted : 01/06/2012 10:32 am
Talk to TF/J-Tech/whoever about your current setup - and they may tune them for your weight/riding style during a service.
Stick with what you have I reckon...
Posted : 01/06/2012 10:35 am
Thanks messiah, I certainly don't dislike them they serve me well. I was considering upgrading to hopefully benefit from the better tech that's all as things seem to move/advance so quickly. I am starting to think a good service my do them some good.
Posted : 01/06/2012 10:37 am
Don't fool yourself into thinking 'better tech' will improve your riding.. LOL
FWIW I ride a 12 year old frame (2000 Patriot), with 7 year old forks (2005 36R). Riding 2012 kit won't help me very much....
How about your spend the money on a skills course? Ok, it's quite off-topic in regards to fork upgrades - but perhaps it's *you* that needs 'upgrading' ?
Posted : 01/06/2012 10:39 am
Brilliant, xiphon/messiah you have convinced me to stick with what I have and get them serviced and tuned....awesome thanks guys you've saved me a few quid.
Ta.
Posted : 01/06/2012 10:40 am
Mmmm....perhaps a trip to see the Jedi could be in order, I like your thinking.
Posted : 01/06/2012 10:42 am
First you have to decide why you want to upgrade (disregarding the shiny shiny new new factor).... then talk to Jedi/any other coach about how their tutoring might overcome the technical barrier.
Or, alternatively, buy some rigid forks 😉
Posted : 01/06/2012 10:49 am
