Get your light beem to go straight and not to the left or right?
Most lights have a small amount of 'twist' in the clamp or similar.
Also, most bars start the sweep a short distance away from the clamping area of the bar.
:lol:Put light on me head or stem?
get a syntace vro stem.only way.
Do you never turn your bars? 😕
No seriously, I only use lights for commuting but not a problem I've ever encountered - lights are always fixed either side of the stem - no sweep there.
Top tip - to get your light beam to go straight, simply undo the bolts that hold the stem to the steerer and twist the bars until the light points in the same direction as the front wheel (then retighten the bolts, obviously - you'd have to be really silly not to do that).
aracer - MemberTop tip - to get your light beam to go straight, simply undo the bolts that hold the stem to the steerer and twist the bars until the light points in the same direction as the front wheel (then retighten the bolts, obviously - you'd have to be really silly not to do that).
That works fine but now my knee bangs on the left bar when pedalling and I can't reach the right bar.
Anyone know of a bar that sweeps forward on the left and back on the right?
That works fine but now my knee bangs on the left bar when pedalling and I can't reach the right bar.Anyone know of a bar that sweeps forward on the left and back on the right?
You're thinking inside the box aren't you? A far better solution is to get your BB re-welded on at the same angle as the stem, and twist your saddle to match.
Thanks I'll try that 🙂
do your bars not have a straight bit next to the clamp? All mine do
Try mounting a light to each pedal.
Or attatch one self contained unit to your front spokes as an incentive to improve your average speed.
